My honda gx160 generator will start no problem run for 2 minutes then cut out it will then start again first pull then same again cut out after 2 minutes any ideas ?
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Check fuel flow to the carb or the latter may need cleaning...
Is the fuel you are using old? If so, might try new gas.
Might have some water in the fuel. I know old fuel gives some of my power tools a tough time sometimes similar to what you are seeing with your generator.
cleaned carb checked fuel flow but still no luck havent changed fuel filter yet!
will give that ago cheers!
