My electric GE range and oven won't go on but the oven light and control panel are lit. No elements will heat. The range indicator red light doesn't go on either.
Sounds like you are only getting 120 volts to the range. If your house has fuses, check for one of the 50 amp ones out. Best if you have a way of testing voltage. Could be a loose / poor electrical connection at the range power recepticle where the cord plugs in, or where the cord connects to the range. Of course it could be in the range wiring or possibly in the range control, but that is not as likely. Get a voltage meter and find out where you are loosing the other half of your 240 volts.
