Logitech R-20 Computer Speakers Logo
Posted on Sep 06, 2009
Subwoofer stopped working
I have the exact same speakers (Logitech R-20) and the subwoofer stopped working after about 2 and a half years since i bought them.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
570
Points
After time they may collect dust. clean them a bit.Do u have an extended warranty. may your should use it . if that does work maybe time for an upgrade..
Chirping noise
The cost is too great to repair.
Logitech R-20 subwoofer not working on windows 7
This undoubtably is a driver problem. You could try running and installing in Administrator, mode and compatability Mode for XP SP2. Either that or ask Logitech whats their fix.
Logitech R-20 + Windows 7 = Subwoofer not working
First check and make sure that the speakers are securely connected.
Then open sound and audio devices, in control panel, and scroll down to speakers,.
click on advance and change the selection to surround. .
click apply and OK you may have to restart to get the effects.
1helpful
Center/subwoofer speaker out...mixed
Hi all, I also purchased a logitech x-540 a few days ago and also have the center speaker outputting sound when i test or play the subwoofer. I didn't think this is normal and am now confused. Maybe its a problem with the audio drivers? MB is a ASUS P6T Deluxe V2 with Soundmax drivers. Hopefully someone can help to diagnose/ find a soluytion.
Subwoofers not working on Logitech R-20 speakers; worked until recently
did you fix it? I have exactly the same problem, I'd appreciate any help please
Adjusting the subwoofer volume seperately from speaker volume
You can't exactly set volume but definitely turn down the bass which lowers the sub's output. Thats all we can do i think.
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
2answers
Unwanted sound from subwoofer.
switch your subwoofer off from the socket for at least 30 minutes and check if the noise is still there,if its still there open it and play a movie then press it lower if the sound stops then you will have to put some toilet papers at the back of it ,thats what I did to mine.
Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
