Question about 50 HP 4WD Tractor w/ Front-End Loader & Agricultural Tires
Instructions how to remove bucket from LS4140 Tractor, cannot find anything to change from bucket to forks?
    Top Expert:
  • 50 HP Master
  • 1,327 Answers
Posted on Jul 30, 2019
SOURCE:
Ford 3000 hydraulic connection
possibly
but only if the lines then goes through the bucket controller valves and the hydraulic oil is compatible
Far better to replace the pto pump
Aug 30, 2018 | Ford Garden
Mid sixties Ford 4000. Suddenly decided to make severe grinding noise when trying to engage gears and cannot engage gears. Weirdly this does not always happen. Gears engage OK when engine not running
Hello, you may have more success in the proper category of lawn or farm stuff. Fortunately I have same Tractor. Sounds like clutch fork is not moving clutch the same way each time you press clutch. Could be clutch needs play removed. Sometimes there is a pivot ball for the clutch fork to rest on. When the pivot ball is worn the clutch fork can rock. Also remember RPM to give gears time to stop spinning before changing gears.
Jan 21, 2017 | Ford Cars & Trucks
ALTEC BUCKET TRUCK STABILIZER CYLInDERS WON'T RETRACT
make sure that the truck is in the ready to move configuration--
bucket properly stowed booms in etc as there may be micro switches that will not allow pressure to return from the cylinders until this is all achieved
The system has safety devices that will not allow operation until it is properly leveled or will not allow stabilizer operation until the machine has been properly made ready for travel
read your operators hand book and safety instructions
Jan 17, 2016 | Custom Manlift Hydraulic Scissor Lift...
How do i change fork seal of kmx 125 a12
Well put on engine stand remove front wheel then mark yokes and fork alignment with marker pen undo retaining clamps on yokes if your forks are upside down ones then undo top cover s then there should be a bolt that holds the inner leg to the fork sleeve once u have removed fork leg remove inner leg from sleeve then you will be able to see the retaining clip inside the sleeve remove this then using a large flat screwdriver get under rubber seal and prize out they are not always easy once done replace with new seal reassemble refill FORK OIL !!! THEN reassemble forks to bike job done
Nov 27, 2014 | Cell Phones
Changing fork oil
Remove forks from bike, with each fork remove end cap and drain plug over a bucket drain oil from each fork reinstall drain plug on lower leg, replace oil thought top of the fork to spec, replace end caps and bleed oil from forks
Apr 18, 2014 | 2004 KTM 50 Adventure Senior
1996 Honda RVF 400 NC35 how to change the fork seals @
This type of R/R is what I call a straight monkey see...monkey do repair. Undo the drain screw on each fork and drain oil. The bike must be high enough off the ground to slide the sliders off unimpeded. From there let pressure off via the schrader valves on the forks, if so equipped. Remove wheel and unbolt anything attached to sliders because these must be taken to the bench. At the bottom of each slider, remove bolt and slide the slider off fork tube. Take slider to bench and remove internal snap ring and carefully pry the old seals out without damaging anything. Grease the new seals and carefully tap seal into slider evenly. A deep well socket can be used to tap it all the way in. From there it's reverse procedure. Add fork oil to specs.
Jun 01, 2012 | 1996 Honda RVF 400 NC35
Tractor ran out of gas, put more in, now won't start again
battery may be weak, must have fully charged battery to sustain operational working condition, or alternatoor may be out, anyway check electrical system
Sep 10, 2009 | RTO Tractor Forks Bucket Forks, Pallet...
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i change the front fork oil seals?
first you will have to remove the front forks by removing front wheel assmbly and anything thats attached to it.
Jun 24, 2009 | kawasaki Z 750 Motorcycles
50 HP 4WD Tractor w/ Front-End Loader & Agricultural Tires Logo
Top 50 HP Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a 50 HP Sport and Outdoor - Other Expert? Answer questions, earn points and help others
