SOURCE: Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
SOURCE: 2 month old Lochinvar Electric 30 gal heater hot
is it a new well.......it may go away after a while...its sulfer....sometimes when you drill well too deep you get sulpher water......
SOURCE: Solar with electric back up hot water tank.
Hi, Here is a tip that will help you...
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
heatman101
SOURCE: Excess Hit Water Bill from Solar/electric Hot Water System
10-30-12
Cost calculations for recirculation system vary widely.
These systems cost more, and they cause higher operation cost of water heater.
1) When pump is OFF, then hot water is no longer leaving the tank.
Most recirculation systems have choice of timer for setting specific times of operation, or thermostatic operation that activates pump when sensor detects temperature less than 90 degrees
BUT...
2) Condition of plumbing is suspect here because you are not receiving fully 90 degree hot water from the recirculation system.?.
Bad single-handle faucet cartridge, or bad recirculation check valve, are causes of crossover. Clean recirculation check valve with white vinegar. Replace worn faucet cartridge.
Test for crossover.
http://waterheatertimer.org/Crossover.html
3) There are other suspects, such as water leak.
Drips, broken pipe, bad TP valve.
Turn off all taps and put ear against pipe to listen for running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
4) High costs: Lifting single-handle faucet in middle will immediately cause cold water to enter tank. Even if no hot arrives at tap, because the cartridge is drawing both hot and cold in equal amounts when handle is lifted in middle.
Today it is more efficient to install dual-handle faucets so tank is not receiving constant dose of cold water when single-handle faucet is not used correctly or tediously.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
If you turned the electric off before draining, Air gets into the system. It will sound funny untill all the trapped air gets "washed" out of the system. If the electric was left on when refilled, you may have a steam generating situation, causing the chugging.
