SOURCE: DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
SOURCE: Remote control
Which universal remote do you have? Any of the Harmony remotes should be able to control the panasonic.
SOURCE: Any button pushed on my remote control causes ''SET 1'' on display.
Hi, All you need to do is point the remote at your DVD player and hold both the number "1" and "enter" keys down for about 10 seconds. Evidently that re-sets the remote. It worked for me so good luck.
Pete
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
