IF it is a Head gasket leaking into a cylinder you wouldent see smoke you would see white steam coming out the exhaust tail pipe and you should get temp creeping up as the further you go and by wrights you should be getting a missing in that cylinder as you cannot {run on coolant but you can on diesel}, but if you find its the coolant getting either in through the seal under lip on liner or head gasket leaking in coolant but will get a lot worse before getting better as only needs a hair crack to cause your problem..
Unfortunatly ford has had problems with the head gaskets on this model.its prob leaking into your cyclinders. worst case ive seen is the engine hydro lock.
