Recently I have noticed that my dishes are not coming out very clean. But now I have the problem of opening up my dishwasher after the cycle is complete and the detergent is not used, but the little door is open. I have a turn dial Frigidaire Precision Wash System Ultra Quiet Model # FDB641RJB0. Does anyone know what could possibly be wrong?
SOURCE: Dishwasher not cleaning the dishes
Hi there. Here are some solutions that may help you combat this issue with the non cleaning of the dishes during the wash.
• Choose another cycle for longer washing
time.
• Check rack loading section for proper
loading—avoid nesting items.
• Home water pressure may be too low—
should be 20 to 120 pounds per square inch
(psi).
• Check incoming water temperature. It
should be at least 120°F (49°C). (See
Factors Affecting Performance.)
• Check water hardness. For extremely hard
water, it may be necessary to install a water
softener. (See Detergent Chart.)
• Use fresh detergent.
• Check to make sure funnel in top rack is not
blocked.
• Make sure items are not blocking the spray
arms, preventing them from rotating.
• Check to see if the rinse aid dispenser
needs refilling.
Next, you mentioned in your text that you were experiencing a burning scent after the was or during it. i have a few solutions for that as well.
• Soiled dishes left in dishwasher too long can
create an odor. Use Rinse & Hold cycle.
• There will be a "new" smell when first
installed. This is normal.
• Check to see if unit is draining properly.
One more thing, sometimes food or plastic dishware will fall between the spaces in the basket that holds the dishes. these plastics can be burned by the heating element inducing a burning scent during the drying process. always make sure that all plastics are secure before you start the cycle. food can get stuck on this heater element as well causing a burned smell.
SOURCE: Powder detergent not distributing in ge quiet power 3 dishwasher
Try storing your powder in the dryer cupboard or in a warm area
It is more than likely that it is damp when it is going into the machine which means it clumps up instead of mixing with the inflow of water
Other thing to check is is there is a restriction at the back of the dispenser drawer which is not allowing the powder to flush down into the machine.
Finally , dry the dispenser slots with kitchen roll and give them a spray with a good quality furniture polish, allow it to dry for a few minutes and then buff it with a cloth, the silicone or wax in the polish should help the powder to slide
SOURCE: Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
SOURCE: my diswasher is leaving a grimy film on all the
Go to you local Supermarket and purcase a bottle of disjwasher cleaner is about 8 bucks a bottle in some cases you may need to use two bottles I would buy 2 but use just one if it works save the other one for a future occasion.Follow all directions on bottle..Make sure you use it in an empty dishwasher and turn hot water tap on closest to dishawsher to make sure it is filling with hot water...You will be quite surprised at how clean your first load of dishes will look after the cleaning
SOURCE: Won't turn on. Frigidaire, precision wash, ultra quiet 1
I have the same issue and it occurred around the same time as your post. Do you think there is a conspiracy? :-)
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
