Rolspel/dialog met 3 persone - Computers & Internet
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Sis mirage 3 resolution 1440x900
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 09, 2012 | ASUS Computers & Internet
The word is "Reserve''. When
this means that this person listed with a minimum amount that they would accept, that the reserve, when the reserve has not been met, usualy the seller will relist the item and try again. if you had saved that item listing in your watched list and you try to go to it, it should tell you that the auction for that item ended and will indicate if seller has relisted..hope that helps..
Sep 13, 2011 | eBay Auctions
What to do if bootmanager fails?
hi frenofurs05,
Thank you for the post.
I suggest trying the following methods to troubleshoot the issue:
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Method 2: Rebuild BCD
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec /RebuildBcd , and then press ENTER.
Method 3: Use the Windows Recovery Environment (WinRE) to run System Restore ============================================
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Note:I just pasted this answer from other person cause its very long when i will wrote it and i think the better one than my explanation.
regards,
mastergani
Jan 03, 2011 | Toshiba Satellite L500 Series Notebook
I have a Scale Master 2 i want to get it to english standard from the metric that it seems to be stuck at, help
For Scale Master Pro XE Advanced Digital Plan Measure Model 6135 (with PC interface cable Part # 5006).
Switch the Imp/Met Switch to Met
While in Metric mode, MET will remain lit in the display
For Scale Master II v2.0
1)Turn until off via switch
2)Press and hold [SUB] key
3)Turn unti on via switch
4)Release [SUB] key
While in Metric mode, MET will remain lit in the scale box.
Repeat procedure to switch back to Imperial mode.
Sep 23, 2010 | Calculated Industries Scale Master II w/PC...
What are personal payments? Can personal payments to India be made?
personal payments such as depositing a cash from bank on the account of other person or it can be personal payments of 2 persons met to gave the cash personally...
- i read some articles in google that personal payments to and from INDIA was suspended for a few months
Mar 27, 2010 | Computers & Internet
Whenever I open a new spreadsheet now it automatically opens up a spreadsheet calles PERSONAL. Why is that and how can I get rid of it... I think it started after a did a macro but I am not sure. Thanks,...
You're right - it was caused by recording a macro. When you record a macro you are given the option to store the new macro in "This Workbook", a "New Workbook" (the default), or in a "Personal Macro Workbook". It looks like you selected "Personal Macro Workbook".
The recorded macro is stored in a special workbook called "Personal.xls". This workbook is loaded every time Excel is loaded. If you don't want this workbook loaded, then just delete it or rename it.
The file is buried deep in Microsoft's application data area. On my Vista computer it's in C:\Users\frogfund\AppData\Roaming\Microsoft\Excel\XLSTART On my Windows XP computer it's in C:\Documents and Settings\frogfund\Application Data\Microsoft\Excel\XLSTART. Depending on your computer your Personal.xls might be in a slightly different location. You might need to do a search using Windows Explorer.
If you are still having troubles finding personal.xls 1. Open Excel, 2. Open the Visual Basic editor (hit Alt-F11 or click Tools-Macro-Visual Basic Editor) 3. Click Tools-References to bring up the references dialog 4. Click on VBAProject in the list. The file location will be displayed near the bottom of the dialog box. Sometimes this might be cut off at the end, but it should give you a good idea where the file is located. 5. Click Cancel to close the dialog.
Sep 23, 2009 | Microsoft Office Excel 2003 for PC
Motorola W377 sends same message twice
Always From The Same Person? If So Its The Other Persons Service Doing It. If Its From Everyone That Way Call Your Wireless Provider And Tell Them About The Double Texts And They Should Offer Compensation.
Jan 05, 2009 | Motorola Mobility W377 Met Silver/Pink...
I want to learn to download my email addresses and Favorites info to my flash drive before mailing computer to HP for repair
How to back up Outlook Express items loadTOCNode(2, 'moreinformation'); Step 1: Copy message files to a backup folder loadTOCNode(3, 'moreinformation');Step A: Locate the Store folder 1. Start Outlook Express. 2. Click Tools, and then click Options. 3. On the Maintenance tab, click Store Folder. 4. In the Store Location dialog box, copy the store location. To do this, follow these steps: a. Put the mouse pointer at one end of the box under the Your personal message store is located in the following folder box. b. Press and hold the left mouse button, and then drag the mouse pointer across the Your personal message store is located in the following folder box. c. Press CTRL+C to copy the location. 5. Click Cancel, and then click Cancel again to close the dialog box. Step B: Copy the contents of the Store folder 1. Click Start, click Run, press CTRL+V, and then click OK. 2. On the Edit menu, click Select All. 3. On the Edit menu, click Copy, and then close the window.Step C: Create a backup folder 1. Right-click any empty area on your desktop, click New, and then click Folder. 2. Type Mail Backup for the folder name, and then press ENTER.
Aug 05, 2008 | HP Computers & Internet
Open Questions:
Computers & Internet Logo
16 people viewed this question
Ekse
Alun Cox
