My compaq laptop won't charge and I just bought a new Targus universal charger using tip #L107. The original power cord didn't seem to work and now the new one won't either.
want to know why my hp laptop charger stopped working whiles charging the laptopwant to know why my hp laptop charger stopped working whiles charging the laptop
You can't post conmments that contain an email address.
It looks like there is a shorting taking place whenever you insert the power jack into the laptop. Most likely the shorting is taking place on the laptop side and requires replacement, which should be done at the manufacturers service station even if its warranty has expired.
The laptop does not recognize the charger due to a different wattage/ amperage or is not powerful enough to charge the laptop while the machine is powered. I have seen many problems with hps/compaqs and the Targus Universal Charger and recommend the HP universal charger for those models instead.
the problem is the BIOS of the Dell system is looking for an ID signal from the AC adapter so it knows what adapter is connected. If the BIOS cannot ID the power supply, then battery charger is disabled.
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
