I have a mitsubishi dlp tv model wd 52725. i replaced the lamp bulb about 2 months ago. when i hit the power on button the tv sound comes on but no picture. the tv will stay on for 2 minutes or so with no picture and then power off and the lamp button on the front of the tv turns orange. i have to hitthe reset button to try again. it does this over and over. every once in a while it get a picture, maybe after 8-10 tries of getting the orange lamp light and then resetting. the lamp is practically brand new so i cant see that being the problem. any help would be appreciated.
I have almost the same problem except sometimes the picture will come on and sometimes only audio. Hit the reset and everything returns to normal until a day or 2 later. I am on my 2nd lamp and it is only couple months old as well.......very coincidental
The red "lamp" light lit, so I replaced the lamp. The TV turns on, a low lighting appears on the screen, then goes out, and then the red "lamp" light comes back on.
I have a similar problem. Dark screen with sound and the power button illuminated. I opened the bulb compartment, looked at the bulb, and everything seemed fine. Put the bulb back in and the television worked. Turn the TV off, and came back later to the same problem. I thought that simply pulling the pull on the unit would reset it, however that was not the case. After resetting the power, unit did the same thing, dark screen with sound. Opened up the bulb compartment again , pulled the bulb, installed the bulb and everything worked fine. Looking for help!
Same problem here. lamp failed in less than 2 years... Tweeter was NO help and very short... replaced the lamp... works if I unplug and plug back in after a few minutes. If turned off, will not come on the next time. Plug for the cartridge and seating looks fine!?!?!?!?! Wish I never bought it.
I replaced the bulb last week, and the TV came on fine afteri plugged it back in, after i powered it off however and i go to turn it on, it acts like it wants to power up, but then after a couple of minutes the amber/orange ligh comes on, now if i take the bulb out that i replaced it mut reset something and the TV will work fine, but when i turn it off I have the same problem, I heard I need a code to repair the problem to reset the board and ishould be fine, is this correct? I will keep searching until i find the solution unless u can help, I hit the Input and menu button at the same time, and I'm getting three flashes then four, so 34, is there a solution to this number, i Have model number WD 52327...
I have the same problem. No picture on an 18 month old tv. I replaced the lamp and get the same thing, no picture and the light on under lamp. I have tried the reset button to no avail. I see where ctf1800 says the plug that connects underneath is not connecting right and that you have to seat it correctly, but am not sure where he means. Does he mean the plug underneath the TV, underneath the bulb, or somewhere else? Help please!
I see what seems to be a scratch on the bulb. Could this be causing the line through the picture?
WE HAD THE DIP CHIP REPALCED ABOUT 2 MONTHS AGO AND WERE TOLD THAT THE LAMP WOULD POSSIBLY BE THE NEXT THING NEEDED TO BE REPLACED COULD THIS BE THE PROBLEM?
WE HAD THE DIP CHIP REPLACED ABOUT 2 MONTHS AGO AND WE WERE TOLD THAT THE NEXT THING WOULD BE THE LAMP THAT MIGHT NEED TO BE REPLACED COULD THIS BE THE PROBLEM?
Picture flashes and little color
