I am looking for a remote code for the emerson LCD to work with the Comcast remote...any suggestions?
NEED TV CODE FOR SCIETIFIC ATLANTA REMOTE 8560
First this is for anyone using a Scientific Atlanta cable box assuming your cable company is giving out these newer remotes. I just got a new 8300HDC box from my local cable company in Largo, FL (Tampa Bay market) along with a new remote. My cable company is Bright House Networks.
The remote details are below and also keep in mind that all remotes I've had from BHN before have failed to work with this LCD TV set.
The remote is a CLIKR -5 Cable Remote Control. These are the model numbers on the operating manual that came with the remote.
UR5U-8700L & UR5U-8720L.
I used the last code under the TV section under the brand Emerson. This code is 514. Also this code is the first code under the list of codes for section "TV-LCD & Plasma TVs" just so you know.
I know this doesn't help anyone with another brand box but I'm sure this specific type of remote (remote with working code) will very soon be available to most if not all markets with Scientific Atlanta boxes which is quite a bit of people.
Also after entering in the code but before pressing the "TV" button to confirm the code if you try and use the volume keys it will only work one press at a time so you cannot hold the volume keys to turn the volume up or down very fast. However once you press the "TV" button to confirm the code you can press and hold the volume keys to turn the volume up or down very fast. The power button, volume buttons and the mute button all work using this code.
At least this gives most here hope that other boxes (ie Motorola cable boxes etc.) might also be getting newer remotes with working codes while Scientific Atlanta boxes currently have newer remotes with working codes available to at least one major cable market. Also the Tampa Bay market is one of the top 5 cable markets in terms of customers.
So for those of you with Scientific Atlanta cable boxes making a trip to your local office could be worth your time now right!!!!!!!!!!!!!!!!!!!!!!!
Below are the codes for use on Emersons remote. I believe the codes are the same for any remote. Haven't tried them yet, but same problem as ladyenglar
Had to get a replacement from emerson, then that wouldn't work so the receiver was bad. Had to return the tv to store (first week I owned) and start over.. That was in June 2007. Been working great ever since.
Which code? The Only Code for the TV (Emerson 32" HD) is for the parental block.....mode....
SOURCE: Need TV code for Emerson HDTV LC320EM8A
I was successful in finding codes on this site that were not listed in the manual:
Direct TV Remote Codes
SOURCE: rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
I also need the code for the remote
need code for scietific atlanta 2100 remote to control this tv
I need the code also. Thanks!!! [email protected]
I also need the code for programming a remote control.
Having the same problem with Knology Cable and an Emerson LC320EM8A. They are using an Atlas Universal Remote and no code is working.
Can not program TIVO remote.- Emerson LC320EM8A. C S
I AM HAVING THE SAME PROBLEM
cant program directtv remote to emerson hdtv no code works
i am having the same problem with my 19 inch Emerson lc195em8 series flat panel. Have bought 3 remotes and had two older here. none work , not even the emerson universal remote I bought.
Same problem Dish wont work and no universal will either.
Need code for LC320EM8A
i have two emerson HDTVs and cannot get the direct tv remote to control them.
can't program universal remote
can't program direct tv remote
Cant program TIVO series 1 remote for EMERSON LC320EM82S. I've tried every code in the book and also code search.
NEED CODES
I have an emerson lcd hd dtv and my directv remote will not work tv either.
When you first turn on the tv the sat. remote will not work,wait 10 minutes then it will begin to operate the sat.box (Direct TV) and no codes will program the sat. remote to operate the tv. WHY?
I need a remote code for an Emerson LC320EM8A Digital HD TV, using an Atlas DVR/PVR 6 Device.
need 4 digit remote code for emerson lc320em8a auto search does not work also the 20 codes that came with remote do not work
Need code also!
I have this TV and cannot find a remote code for my Wide Open West Universal DVR remote. Please help or send reply to [email protected]
NEED A DEVICE CODE FOR SYLVANIA LCD MODEL #LC370SL8 TO WORK WITH DISH TV REMOTE 5.3 IR ECHOSTAR
i can get my emerson hdtv work with any universal..... ;( whats the problem?
need code on emerson hdtv will not work on dish network remote
I have the same problem , the only solution I found is to purchase a remote where you can record the signal from the OEM that came with the TV.
cant find code for flat screen hdtv,emerson so my dish remote will operate my tv.Juggleing 2 remotes is a pain in the ****.Tried going thru every code for emerson in the dish book.Desperate please help!!!!!
LC320em82 need codes
the 19" has the same problem...
I'm having the same problem. Using two remotes stinks. Anyone find the code for the Emerson HDTV?
Same for me.
I have the same problem. I cannot get it to work on a One For All 4 in 1 remote or a Dish Network remote
can not get my dish network remote to operate TV
I bought a display model so if someone has a universal remote that works I would appreciate knowing what brand
Can't get my Directv remote to accept any codes for my Emerson 32 inch Hd TV
We lost the remote for our Emerson HDTV 32" Model # HLC320EM8A. I have bought and tried 4 (no kidding) different universal remotes and not one of them will work with this TV. I went through all the Emerson codes listed in the universal remote manuals and I also did the search. This is crazy. Where can I order an Emerson remote replacement? or What universal remote can I get for this TV that will work?
Appreciate the answer from anyone that has it.
My original remote stopped working. I've called customer service from both the universal remote company and Emerson neither of which were of any help. Emerson just says to keep trying remotes til I find the right one and didn't know if I could order a replacement ( WTF) and the universal remote customer service says my tv's sensor must be bad....wow how can the make a tv cannot be paired with a replacement or provide a place whereas you could purchase a new one.
need code
lc320em9
I see one the owners manual that this particular set# was reconditioned by Funai Corp. Have tried all their codes as well as some other brands on their website. Still nothing!!
Has anyone found a universal remote to work with the emerson LC320EM9 yet? I see replacement remotes online for 40 bucks, but that is too high. Any help would be appreciated.
need code for oneforall remote control
