I use my nokia n70. in which i have problem.
it is that when i turn the phone on i cant hear the starting sound and then i see the earphone symbol as connected. but i havent connected any earphone then to i can see the symbol on the screen. and i cannot hear the sound outside normally.
only when i connect ear phone i can hear...
so whats the problem?
can u help me..???
reply me at:- [email protected]
Simple solution,open your mobile cover and clean your earphone socket and make the two bruss colour pin which connect your earphone with circuit little high so that it connect both the part each other,
Switchoff your Phone and Switch it ON.
Still same Try to Plugin your Headset and Remove it. Again you face same Go to settings> Restore Factory Settings>Enter Phone Code[Default is 12345 if not changed earlier-All 'phone data will be lost-Backup it to MMC before doing it]..
Hope your problem solved....
NOTE:Still same problem-Check your Connectors> Audio ways and IC.
Try removing the battery for 5 minutes and then replace and see if
that makes any difference.
If that doesn't work, try these. (Make backup of first)
*#7780# - Restore factory settings *#7370# - Reformat your phone
If they still fail: 1. remove and replace the battery 2. press and hold these 3 keys while turning the phone on: " * ", " 3 ", and " green phone button " continue holding the three keys until you hear the start up sound.
If all the above fails, you may have a broken screen connector or bga chip which will require you to open the phone and replace.
this could be dirt traped in the socket and the phone thinks its connected try blowing into it you should take it to a nokia care point anyway as iit sounds like the internal speaker is gone
ur phone as been hucked and it will be not solove with ur known and u should go the nokia center and ask him to back repair it happen with some virus or some data has delected or try it u should remove the memory and sim card ok rate me please
may I ask, although the display is white can you still hear a tone? Or if you restart your phone you still hear a tone.
If yes..maybe the connector that conects your lcd to the main board is lossen. it happens when the phone is accidentally drop. If you know how to open your phone, try to tighten all the screws inside and start.if nothing happens. Try to replace your lcd with a new one.
OR
Consult your dealer for posible factory defect. ^_^
