What application can be used for my field tv from my smartphone
I have a Nokia e7 smartphone and need a nokia account
Discontinued!
What is the use of Nokia account? Nokia Account uses your email address, phone number or username and password to identify you when you access Nokia applications. You created a Nokia Account when you set up your Nokia mobile phone or when you first used a Nokia application.
'Nokia Account Discontinuation' on April 25th
allaboutwindowsphone.com/flow/item/20505_Nokia_Account_Discontinuation_.php Search for: What is the use of Nokia account?
  1. Swipe left to view the Apps list.
  2. Tap Settings.
  3. Tap Email + Accounts.
  4. Tap Add an Account.
  5. Tap Nokia Account.
  6. Tap the Email field.
  7. Enter your email address details.
  8. Tap the Password field.
More items...
Create a Nokia Account - Windows Phone 8 - Spark
https://www.spark.co.nz/help/mobile-data/.../create-a-nokia-account-windows-phone-8/ Feedback About this result
My Account / Register - Invent with Nokia
https://inventwithnokia.nokia.com/registration
  1. Cached
  2. Similar
My Account / Register · What are the financial terms? Blog · Login · Register · My Account / Register · What are the financial terms? Home > My Account ...
https://www.spark.co.nz > ... > Mobile & Data > Device > OS > Windows Mobile
  1. Cached
  2. Similar
Swipe left to view the Apps list. Tap Settings. Tap Email + Accounts. Tap Add an Account. Tap Nokia Account. Tap the Email field. Enter your email address details. Tap the Password field.
How To Create a Nokia Account - Ccm.net
ccm.net > How To > Mobile > Nokia
  1. Cached
  2. Similar
Aug 16, 2016 - Note: The Nokia Store was discontinued by Microsoft in 2015. At that time, all users were transitioned to the Opera Mobile Store, which now ...
need nokia account Google Search
Dec 22, 2016 | Nokia Cell Phones
Errror message JVM error 102 appears on screen
Problem
The BlackBerry smartphone stops responding and displays the following error message:
JVM Error 102
Cause
A problem exists with one or more of the .cod files on the BlackBerry smartphone.
Resolution
Before completing this resolution, download and install the latest version of BlackBerry® Device Software from your service provider's web site.
Re-install the BlackBerry Device Software and applications to your BlackBerry smartphone by completing the following steps:
Warning: The following procedures will delete either all data or all data and applications from your BlackBerry smartphone. Back up your data before performing the procedure. For instructions, see KB12487.
Connect your BlackBerry smartphone to your computer.
Open BlackBerry® Desktop Manager. Note: BlackBerry Desktop Manager may display "Disconnected." If this is the case, proceed to the next step to correct the problem with Application Loader.
Click Application Loader. The Application Loader Wizard appears.
Click Next.
Choose the port that the BlackBerry smartphone is connected to and click Next.
If prompted, type your BlackBerry smartphone password and click Next. The Device Application Selection screen appears.
Select the applications that you want to install on your BlackBerry smartphone.
If the Device Backup screen appears, choose whether or not to automatically back up the data on your BlackBerry smartphone. Click Next.
Click Next.
The Completing the Application Wizard screen appears, displaying all the software that will be installed on your BlackBerry smartphone. Click Advanced and make sure that Erase all application data and Erase all currently installed applications are both selected.
Note: If the application loader tool was not able to access all of the data on your BlackBerry smartphone, then the following two fields are grayed out: Erase all application data and Erase all currently installed applications.
Click Next.
Select Do not automatically create a backup and click Next.
Click Finish. The BlackBerry Device Software will be installed on your BlackBerry smartphone. Do not disconnect your BlackBerry smartphone until the process has completed.
Axl
May 04, 2010 | RIM BlackBerry Bold 9700 Smartphone
HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
On my BB 8700g 4.5 when I try to open SugarSync I get this message: "the application sugarsync has attempted to open a connection to a location inside the firewall and outside the firewall which is not...
When you are trying to open a third party application on the BlackBerry smartphone, the following error message is displayed: The application {application name} has attempted to open a connection inside the firewall and outside the firewall which is not allowed by your IT policy. This issue is caused by a restriction in the BlackBerry smartphone's firewall.
To remove the firewall restriction, complete the following steps:
  1. On your BlackBerry smartphone, go to Options > Security Options > Firewall.
  2. De-select Enterprise Messaging.
  3. If this does not work, turn off the firewall by selecting Disable in the Status field. If you are not able to turn off the firewall, contact your IT Administrator as there is an IT policy restricting your firewall settings.
Hope I helped you.
Nov 10, 2009 | RIM BlackBerry 8700g
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
My phone is deleting my text messsages and my calls I have made. When I go to check if my message sent, it says there is nothing in my inbox or outbox. How does my phone delete my stuff without me doing...
Cause 1 A number of large applications are installed on the BlackBerry smartphone. Resolution To resolve this issue, complete the following steps: Make sure that the BlackBerry® Device Software is installed on the computer to display the correct total application space. Determine the application space that is available on the BlackBerry smartphone by completing the following steps: Connect the BlackBerry smartphone to the computer. Open the BlackBerry® Desktop Manager. Double-click Application Loader. At the Device Application Selection screen, under the application selection window, note the total application space. Note: Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes. Remove applications that are not required. For example, remove additional language packs and themes. Cause 2 A large amount of BlackBerry smartphone user data is present on the BlackBerry smartphone that cannot be removed by the Low Memory Manager. Resolution To resolve this issue, complete the following steps: On the BlackBerry smartphone, click Options > Status. Display the menu, and select Database Sizes. Reduce the number of items that are increasing the size of the database. For example, if the Address Book database is large, remove out-of-date contacts. If the Content Store database is large, move media files from the BlackBerry smartphone memory to a media card. Cause 3 Media settings may contribute to low memory capacity. Resolution Modify the Device Memory Limit settings by completing the following steps: On the BlackBerry smartphone, click Media. Select a media application. Display the menu, and click Options. Set the Device Memory Limit to the lowest setting field. Display the menu, and click Save. Note: Some BlackBerry smartphones have integrated cameras without a media card. As a result, some features have been added to handle picture storage on the BlackBerry smartphone, including the following: · Reserved Pictures Memory: In BlackBerry Device Software 4.2.0, the default value setting is 10 MB. In BlackBerry Device Software 4.2.1 - 4.7, the default value setting has been reduced to 2 MB. This setting reserves memory for pictures that the BlackBerry smartphone might take, and reduce the File Free amount that is displayed in the BlackBerry smartphone. This makes sure that the BlackBerry smartphone has memory available for pictures that are taken when a media card is not inserted in the BlackBerry smartphone. · Device Memory Limit: The default value setting is 20 MB. This prevents the BlackBerry smartphone from storing more than the specified amount of memory use. Cause 4 An application has expanded beyond intended memory boundaries. Resolution Note: In the Java® operating environment, applications increase and reduce memory usage when the applications launch, run required processes, and close processes. An application may use more memory than it is intended to use. Please make note of the values outlined in the following steps: On the Home screen of the BlackBerry smartphone, click Options. Click Status and note the values listed for File Free and File Total. Divide each of these two values by 1024, so that they are measured in kilobytes (KB). Record the new values, and name them as Displayed File Free and Displayed File Total. Display the menu, and click Database Sizes. Record the value shown in the Total Size field at the top of the screen. Open BlackBerry Desktop Manager, then open the application loader tool. Click Next on the Welcome screen. Connect the BlackBerry smartphone to the computer and allow the application loader tool to detect it. You might be prompted to type a password. Click Next on the Device Application Selection screen. Verify that the List additional applications that are installed on the connected device check box is selected. Record the value for the Total application space, located at the bottom of the window. Calculate the Reserved Pictures Memory for BlackBerry smartphones that have integrated cameras. If a camera is not integrated, proceed to step 12. On the BlackBerry smartphone, open the Media application. Display the menu, and click Options. Note the Reserved Pictures Memory value and multiply that value by 1024. Record the value. For example, 2 MB * 1024 = 2048. To calculate the Total Amount of Memory In Usage, add the values for Total Application Space, Total Size, and Reserved Pictures Memory (if applicable). To get the Calculated File Free value, subtract the value for Total Amount of Memory In Usage from the Total Flash Memory supported by the BlackBerry smartphone.
Oct 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
How to open ethernet??
Task 1 - Turn on the Discoverable option on the BlackBerry smartphone Complete the following steps:
  1. On the Home screen of the BlackBerry smartphone, click Options > Bluetooth.
  2. Display the menu and click Options.
  3. Set the Discoverable field to Yes.
  4. Display the menu and click Save.
Task 2 - Pair the BlackBerry smartphone and the computer On the computer, complete the following steps:
  1. Go to Control Panel > Bluetooth Devices.
  2. Click Add.
  3. Select the My device is set up and ready to be found check box, and click Next.
  4. When the BlackBerry smartphone is detected, select the check box next to the BlackBerry smartphone, and click Next.
  5. Select the Let me choose my own passkey option.
  6. Type a passkey in the field provided, and click Next.
  7. On the BlackBerry smartphone, type the same passkey from Step 6, then click the trackball.
  8. On the computer, when the Completing the Add Bluetooth Device Wizard screen appears, click Finish.
  9. On the BlackBerry smartphone, when prompted to accept an incoming Bluetooth connection, select Don't Ask Again, and click Yes.
Task 3 - Set up the Internet access point name (APN) Note: You only need to perform this task the first time that you set up the Internet APN.
Note: If you are running Windows Vista, select Classic View.
  1. Go to Control Panel > Phone and Modem Options.
  2. Select the Modems tab.
  3. Select Standard Modem Over Bluetooth Link, and click Properties.
  4. Select the Advanced tab.
  5. In the Extra initialization commands field, type the following: AT+CGDCONT=1,"IP","<your Internet APN( for eg: aircelgprs)>"<cr>
Task 4 - Configure Dial-Up Networking Note: You only need to perform this task the first time that you configure Dial-Up Networking.
  1. Go to Start > Settings > Network Connections.
  2. Right-click Bluetooth DUN connection, and select Properties.
  3. Select the Networking tab.
  4. Select Internet Protocol (TCP/IP).
  5. Click Properties.
  6. Click Advanced.
  7. Select the General tab, and clear the Use IP Header Compression check box.
  8. Click OK to close all open windows.
  9. Go to Start > Settings > Network Connections.
  10. Double-click New Connection Wizard.
  11. Click Next.
  12. Select Connect to the Internet, and click Next.
  13. Select Set up my connection manually, and click Next.
  14. Select Connect using a dial-up modem, click Next.
  15. Select Modem - Standard Modem Over Bluetooth link, and click Next.
  16. If the Select a Device screen appears, select the Modem - Standard Modem check box, and click Next.
  17. Clear the ISP Name field blank, if necessary, and click Next.
  18. Complete the appropriate step below:
    • If the BlackBerry smartphone operates on General Packet Radio Service (GPRS) or Enhanced Data Rates for Global Evolution (EDGE) networks, type *99# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Universal Mobile Telecommunications System (UMTS) networks, type *98# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Code Division Multiple Access (CDMA) or 1x/Evolution Data Optimized (EVDO) networks, type #777 in the Phone number field, and click Next.
  19. Type the user name and password provided by your wireless service provider. If your wireless service provider has confirmed that this information is not required, leave the fields blank. Click Next.
  20. Click Finish.
Task 5 - Connect the computer to the Internet using Dial-Up Networking Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session may interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Click Start > Settings > Network Connections > <Name of the new connection>.
  2. Type the user name and password provided by your wireless service provider. If your wireless service provider does not require this information, leave the fields blank.
  3. Click Dial.
Oct 05, 2009 | RIM BlackBerry 7730
Clock slow
Set the date and time To set the date and time displayed on the BlackBerry smartphone, complete the following steps:
  1. In the Clock application, press the Menu key.
  2. Click Options.
  3. Click Set Time.
  4. Set the date and time.
  5. Press the Menu key.
  6. Click Save.
Retrieve the date and time from the wireless network To retrieve the current date and time from the wireless network, complete the following steps:
  2. Click Options.
  3. Click Set Time.
  4. Set the time zone in the Time Zone field.
  5. Perform one of the following actions:
    • To retrieve the date and time from the wireless network that your BlackBerry smartphone is connected to, change the Date/Time Source field to Network.
    • To retrieve the date and time from the BlackBerry® Infrastructure, change the Date/Time Source field to BlackBerry.
  6. Press the Menu key.
  7. Click Update Time.
  8. Press the Menu key.
  9. Click Save.
Note: To set the time manually, change the Date/Time Source field to Off.
Sep 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
I woke up this morning to find find the screen of my new BlackBerry Curve reading "JVM Error 545 incompatible or corrupt filesystem." It was charging all night. Unless my roommate messed with it, I have...
The BlackBerry Device Software is corrupted.
u need to reinstall the software.
Install the latest version of the BlackBerry Device Software on the BlackBerry smartphone.
The BlackBerry Desktop Manager will not detect the BlackBerry smartphone in this state. To force the BlackBerry Desktop Manager to detect the BlackBerry smartphone, run the Application loader tool. For instructions on how to force the BlackBerry Desktop Manager to detect the BLackBerry smartphone.
Perform following steps
BlackBerry Desktop Manager 4.5.0 and later
  1. Remove the battery from the back of the BlackBerry smartphone.
  2. Connect the BlackBerry smartphone to the computer using a USB cable.
  3. In BlackBerry Desktop Manager, double-click Application Loader.
  4. Click Start under the Update Software heading
  5. The Device Password dialog will display. If the BlackBerry smartphone has a password enabled, enter the password. If the BlackBerry smartphone does not have a password, leave this field empty.
  6. Click OK.
  7. If prompted with a list of Available Updates, choose the latest software version by selecting the corresponding check box and then click Next.
  8. Click the Settings button under the Device backup and restore options.
  9. Make sure that the Back up device data automatically during the installation process check box is not selected.
  10. Make sure that the Delete all application data and Erase all currently installed applications check boxes are both selected.
  11. Click OK on the Settings dialog.
  12. Insert the battery into the back of the BlackBerry smartphone.
  13. In the Application Loader wizard, click Next to proceed with the loading process.
  14. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  15. Insert the memory card, if applicable.
  16. Close the Application Loader wizard.
If you are getting problem in installation of configuration kindly contact me
Please Rate !
Sep 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
JVM Error 102
This is a Java Virtual Machine Error with your blackberry OS. you will need to download a BB OS from Blackberry.com and then runn Apploader from your Desktop manager software. This will wipe and replace the BB OS and fix the issue.
Sometimes a Hard reset can fix this issue though.
If you need further help, please visit www.blackberry.com/btsc
Jul 06, 2008 | RIM BlackBerry 7290
Open Questions:
Computers & Internet Logo
12 people viewed this question
Ekse
Alun Cox
