There are only two parts of a toilet that go bad...the fill valve which lets the water in, and the flap which lets the water out when the handle is depressed. When you look into the toilet tank, if you can hear the water running, look to see if it is high enough to be spilling over into the tube....if that is the case, the fill valve is bad...if you hear the water running, then stopping, then starting again...your problem is the flapper that is leaking slightly. Hope this helps...
SOURCE: not enough water in the toilet bowl
Adjust the floating stopper in the tank to allow more water to fill the tank
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
SOURCE: When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
SOURCE: Weak dual flush does not empty the toilet bowl.
Waste pipe problems aside, if its a dual flush check you are actually working the full flush button and that the mechanism is working properly and not stuck operating only the half flush. If then you look in the tank both the total water level in the tank (white screw at the filling valve) and the quantity of water let go for each full and half flush (blue parts below, in the flush mechanism) can be set to different levels. Yours might be set to the minimum
