Klangtop will not connect to computer have tried everything.
    Habit-Forming:
    New Friend:
  • 123 Answers
You need to update your Bluetooth or your USB driver
Posted on Jul 20, 2019
SOURCE:
Connect computer removable
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Sep 04, 2013 | Sanyo VPC-X1400 Digital Camera
Ethernet conection dosen't work
More than one computer or just one? Sounds like something wrong with the computer lan port.
Jan 10, 2013 | Computers & Internet
Suddenly, my hp printer won't print. I use
try to remove everything from printer that connect to you computer, from you pc remove driver restart and connect your printer it must be a pop up that found new hardware to you computer. in not then you computer not detect that printer. try to replace printer cable. if still not work tr to connect your printer to other computer to conclude where the problem. from printer or from you computer. please give feedback for next trouble shooting.
Apr 13, 2010 | HP PSC 1610 All-In-One InkJet Printer
D-link won't connect to the internet
If you connect the computer directly to the modem , it shopuld work.
If your computer is online when connected only to the modem then the problem must be router settings .
you will need to check the settings manually.
Click Here for step by step solution
Nov 03, 2009 | Computers & Internet
No connection There is no computer connection.
Hello !
Give this a try;
Go to Printers and Faxes and delete your printer icon.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. If it does not, move the USB cable to another port on your computer. It's also possible that your USB cable is faulty - replace the cable.
Install the printer driver.
Hope that helps.
Oct 15, 2009 | HP Office Equipment & Supplies
Dlink wireless wbr1310 connection problem
Try this,
Shut down everything starting with your computer, then the router, then the modem.
Wait 30 seconds. Restart everything in this order:
Modem first (wait for all the lights to come on) then start your router (again wait till everything lights up and settles down) finally start up you computer.
Check to see if you can connect to the routers control panel which is usually 192.168.2.1.
In the control panel there should be a place to enter your computers MAC address, usually under MAC Address Filtering. To find the Mac Address of your computer, go to Start/Run/ when the window opens type CMD and hit enter.
A Dos window should open, type in the following. ipconfig -all
It should then display your Mac Address which you will want to write down so that you have it ready to type into the Mac Address filter .
After entering all the info. Restart everything just as I instructed in the beginning and you should be good to go.
Sep 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Everything appears to be working, but not internet connection
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
May 16, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a netgear router and only two computers can connect to the internet. My other two computers cannot connect. We type in the network password key and everything, but still no connection.
Try connecting computers via ethernet and see what happens.
Try changing Netgear wifi channel to 6 or 8
Try removing encryption and seeing what happens
If it works use a simple WEP 64 bit code
Try removing all wifi entries from your wifi software and starting afresh - too many conflicting entries confuse the system
Dec 19, 2008 | Computers & Internet
Acer P221W 20in blacking out
check your graphics card wait 20 minutes or more see what comes up i recently had that or if u try everything eg replacing everything and it still don t work try rebooting the computer with the recovery disc which means it will wipe out everything programs everything.
Sep 28, 2008 | Acer Professional P211 21" CRT Monitor
Open Questions:
Computers & Internet Logo
41 people viewed this question
Ekse
Alun Cox
