SOURCE: please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the
set, and get the regular red blinky lights, hold down the Device and
Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
SOURCE: turn tv on green light keeps blinking wont reset
Verify Model # off back of set and mo / yr built......critical for
correct solution....For example, if your # ends with.....13, then
a DM module repair will be needed...replace four capacitors...
1000mf 25v 105 degree.....If different model = different solution
....................................T.
SOURCE: blinking light
It could very possibly be ur power supply,mine did the same and we changed it out with a spare and it came right on
SOURCE: Command screen blinks
Hope this help. Please
Rate My Response! Thanks!
PREM
SOURCE: Green light blinking and wont
Hi Thanks for using FixYa. Continuous blinking green LED on Mitsubishi's
Projection which normally blinks after a power surge means that the
microprocessors inside the unit are unable to communicate with each other.
Usually Mitsubishi's Projection TV use 1000uF/16 in the DM MODULE (which is one
of the two microprocessors), as these capacitors are too small for the load
they get they usually fail usually after about 3-5 years. They
might also fail due to voltage fluctuations. To resolve this issue these
capacitors should be replaced with 1000uF/25 volt or 1000uF/35 volt capacitors,
so that they can handle any voltage spikes that will occur. To do the repair
you'll need to take the back off the TV apart in order to remove the faulty DM
module and need to desolder the old capacitors on DM board and install new
ones. All this is only recommended to be done by someone who has electrical expertise. Please accept the solution if the issue is resolved
or post a comment for further assistance. Thanks Rylee
