How to copy movie in a dvd from our pc for playing in a dvd player
Question not clear
I assume that you want to burn movies from your PC to DVD. Then you could use a good DVD burning program to do this(you also have to make sure your PC DVD drive can write data on DVD). You could try Leawo DVD Creator which enable you to burn movies to DVD with high speed and retain the original quality.
Here is a step by step guide on:
How to Copy DVD Movies
It will walk you through the whole process.
To copy from dvd you will need to RIP the movie in media player
Then you will need to burn it in burn list in media player.
For other movies that are AVI files and you want them on disc to play in DVD player, then you will have to download ConvertX to DVD program and convert file from AVI to DVD
SOURCE: dvd+r dl
depends on what format the dvd burner burnt it, mpeg wav avi etc...i had the same problem. basically the older dvd players wont reconize these formats thats why.
SOURCE: dvd player wont play burned movies
most of the movie if download from the net protected my different formating keeping people from burning and selling coppies. as long as your dvd play dvd is working fine. I got lots of those downloaded movies from a friend myself some play and some dont. I bet you if you go through most of your copy dvd some will play and some dont. Your sysytem may read some dvd VS mine may read some of your's that you system dont reads, you will not find a unit" DVD" will deformat the protection copy rights. I have 850.00 unit almost top of the line still wont read lots of copy DVD.
SOURCE: movie don't play even after cleaning dvd player
That should not damage the head. I use those cleaning cd's also without problems. Was it working properly before or was there some problem that required cleaning?
