SOURCE: sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
SOURCE: STAUS INDICATOR SHOWS "L-6" ON SHARP AL-1010
Dear sir; The L-6 error code it means "laser drive, motor", It can be reset, the procedure as follow;
1, press "clear", "exposure mode", "clear", "exposure" those keys.then machine go dead.
2, enter 14, then press print.follow the direction willtake car the problem.
If you need more help just let me know I'm always around, or generously give me good rating. thank you,
HAVE A MERRY CHRISTMAS !!!
SOURCE: SHARP AL-1631 COPIER NOT RESPONDING
try re-installing the software, and re-post if necessary
SOURCE: my sharp printer model No.AL
you may download driver for window 7 from"http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/support--downloads.htm?query=AL2020&var1=AL202&var2=AL20"
you must vote for solution
