Polaroid FLM-3232 Television Logo
Posted on Sep 05, 2009
Polaroid Model 3200 started with no sound then
A loud noise came on and now the TV will not turn on or has any power. Can anyone help.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
500
Points
This happened to my tv as well. I have a 62 inch polaroid. Were you able to fix your tv. If so what did you do and how much did it cost?
3helpful
3answers
I have a 2+ year old Polaroid Model 3200 LCD TV. It will not turn on. The power outlet makes a clicking noise if I mess with the adapter in the back but I don't even get a red light when it is plugged in...
Tv power supply board is the causes and the problems.It dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I have a polaroid 3200 TV while I was watching tv it made a loud noise as if an engine were reving up and then went black when you turn on the tv the blue led illuminates but nothing else. Any Ideas....
msp_pitt, The first place I would investigate would be the units MAIN "switch-mode-power-supply" to see if any capacitors have blown-up or vented themselves to room atmosphere. I would also check the units "inverter supply" board for bad capacitors or other fried components. You may or may not find parts or boards for this unit. could try some place called "shop jimmy" I think. Before you do anything visit YOUTUBE. You might find information there also, or a DIY video of common fixes for SMPS's on your unit. Good luck. 12fixlouie
1helpful
I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by....
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
2answers
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
3helpful
2answers
Have a polaroid tv, model 3700 seriel F0600181940001053. WATCHING THE OTHER NITE AND A LOUD SQUEAL CAME ON AND THE PICTURE WENT OUT, TURN IT BACK ON TODAY AND THE SQUEAL IS STILL THERE WITH NO PICTURE..NO...
I have a flat screen polaroid lcd hdtv model 3700, first the sound started to get really loud with a beeeeeeeeep when we turned on and after a while was gone, now it doesnt! we had to put mute and connect the tv to a sorround system to hear it without that crazy noise, and now the colors of the tv are gone too its just black and white when we try to see the dish satelite but if we put a movie on the dvd player colors are perfect we try to conect the ps3 player too but its black and white too. Help what can it be!!!!????
4helpful
3answers
Polaroid LCD TV Model 3200 - Will not turn on
you have a power supply problem.. I have fixed serveral tvs with this problem. normally you have to replace busted capacitors in the power supply board.
Dead polaroid model 2700 visionquest tv
Your power supply has failed; have it replaced
2answers
Polaroid FLM 3232 is making a loud crackling noise overpowering volume
Your only solution is to change the sound to mono. Eventually the power supply will go and the tv won't work.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
