Navman PiN 570 GPS Receiver Logo
Posted on Sep 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have forgotten the pin number for my GPS how can i reset it
We set a pin number for security on our Navman but it wont accept the number we are sure we used! Now we can't get into the unit at all. Is there some way we can reset this?
  • mareeandnath Sep 05, 2009
    Hi thanks for your response.  When I connect the GPS to my laptop should it bring a box up?  Nothing seems to come up and i can only access it by going into my computer.  And in there under tools there is no option for pins?  Thanks
Anonymous
Level 3:
  • Master 3,741 Answers
  • Posted on Sep 05, 2009
Anonymous
Master
Level 3:
Answers
3741
Questions
0
Helped
974972
Points
10483
If you have forgotten your Pin code, you will need to reset it within NavDesk.
To do this connect your device to the PC and go to:
a. Tools > Pin Security.
b. Log in and enter in a new Pin number.
c. Finish (bottom right hand corner of the screen).
NOTES from me:
1. You must be connected to the Internet.
2. You must have registered your Navman online with Navman.
3. You must remember your LoginName & Password when you registered and use this to Log in for b. above.
4. Your Navman must be on and connected to your PC.
5. From NavDesk software start from a. above.
6. Just enter your "User name", "Password" and "PIN" number to log in to Navman. (Your PIN must be between 3 and 8 numerical digits or leave blank for no PIN).
thanks. please keep updated.please do rate the solution if helped.thank you for using fixya.
  • Anonymous Sep 05, 2009
    is your device registered if not get it registered by entering the navman site.
    then only you will be able to access.
    thanks.
Does anyone Know a golf gps that works on Navman pin 570
Navman is not a USA product and it is not compatible with many apps. Getting Local Maps are not easy either.
Mar 25, 2014 • Navman GPS
When i turn on my garmin nuvi 205 it asks for a pin but i fogot it wha can i do
im sure this is not the answer your looking for, but If you have a Garmin Lock on your nuvi, zumo or StreetPilot c5xx and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device.
If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note we will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
I have a gps and i need an unlock pin cause i bought it and fogot my pin number
Question: How do I unlock my device if I have forgotten the PIN number?
--> Answer: If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device.
To contact Product Support in your area go to http://www.garmin.com/garmin/cms/site/us/support/supportcontact
1helpful
4answers
Unlock gps 760 garmin ilost the 4 pin number
The only way to do it is to go to the location you set as "home" in the GPS. When you are at that location, the GPS will not ask you for a PIN and you can then go in and change the PIN.
If you don't know what the home location is, you'll need to contact Garmin http://www.garmin.com
This link may also help
http://www.garmin.com/garmin/cms/cache/offonce/us/support/searchsupport;jsessionid=EEAD05C5F07256DACD3D5F3E363966C6
There are so many of these being stolen from vehicles, the PIN is designed to make the unit useless to thieves.
1helpful
Cracked LCD screen Navman F20.
any store that sells Navman GPS should be able to accept the repair. It wont be cheap though
Please rate my help++++Thankis for using FIXYA
4helpful
Forgot my pin number
How i can get my pin , i forget . thanks
if you have forgotten your 4 digit pin number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock, otherwise youll have to send it in to garmin to reset it for you.
How do I reset pin number as my husbands son must have messed with it before he put in a pin number . I cannot find any reset button.
1helpful
2answers
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
NAVMAN PIN 570
Try cold boot, that is factory reset button on the right of the power/usb cable slot.
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
