The 30 Amp breaker should be okay for the 5500W water heater. The Rheem Performance Plus 50 gallon water heater, XE50M09EL55U1, requires a 30A breaker for 208V and 240V electrical systems (single or 3 phase wiring). See pages 8-9 of the manual: https://images.homedepot-static.com/catalog/pdfimages/e2/e20f6bed-6a61-43a8-b7d9-d9dd2dae94e1.pdf .
You should check the installation manual for your new water heater, just in case. I hope this helps.
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
I have the same problem about every 3-4 months. Mine is also about 10 or 11. It is usually the sediment at the bottom that causes this. Once the plumber flushes it, it works again. My problem is that I dont know how he did it and the vavle is at the floor level. I am never home when it is repaired. Regular maintenance (flushing) is how you avoid this from reoccurring. That is, if that is the cause of your issue.
