If this is in the context of a program like Excel, View -> Unfreeze. It happens when you have frozen a large number of rows. That, in turn, usually happens if you try to freeze the top row(s) while you have some rows filtered.
I do this to myself frequently. It's an easy blooper, and really irritating.
Try the number lock key
SOURCE: Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
SOURCE: Left & right arrow keys not working.
Try to connect an external keyboard, see if that one works. If it does, then the problem is most likely a loose ribbon cable from the internal keyboard to the motherboard (especially if you recently installed a new one) - also, while you are examining the cable, look for any tears, cuts, or kinks in the cable. Good luck!
SOURCE: hi i am dinesh my
The problem of your phone is ribbon that is the connector that connect to the screen and keypad.. That is the problem of all slider phone .you need to go to nokia care if you have warranty it is free. Rate me if i help
