I have a Whirlpool ED25PEXHW02 that was working fine until last night. The freezer seems to be the same temp as the refrigerator which also seems to be a little warmer but still is cool just not as cool as normal. I am good with my hands but have no experience with refrigarators. Any help would be appreciated. Where do I start?
SOURCE: WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
Please see potential solutions at diychatroom.com. Do a search on "whirlpool fridge flickering". I had the same problem, and the solutions worked - can save you the price of a board.
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
If
you don’t know what these are then unplug the machine and let the ice melt in
the freezer overnight with the door open. Then try it the next day, if is
cooling fine then you need to have a service person replace one of the above
items. If it still has a problem then it might be the compressor and you should
probably replace the machine.
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
SOURCE: FREEZER BUZZING NOISE - Whirlpool refrigerator Model# ED5FHEXNS01
My whirlpool side by side makes a vibrating noise when in cool cycle I press at the back of the panel in the freezer side and it stops
It is stuck in the defrost mode...
Check out these tips...they can help you figure out what is going wrong with your refrigerator Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
