On some models you can move the hinges and door pull to the opposite side. On the side without a hinge, you would see plugged holes (plastic plugs covering the holes). You may have to move the top right hinge to the bottom left and bottom right to the top left (opposite of this for a left-hinged refrigerator/freezer).
Prepare the laptop for disassembly. Shut down the laptop completely, then wait a few minutes before removing the battery and unplugging the AC adapter. Turn the laptop over and lay it down on a flat surface so that the battery area is facing away from you and the hard drive is located at the bottom left corner. 2
Remove the hard drive cover. Remove the two screws located on the left side of the hard drive cover, then lift the cover to remove it completely from the unit. 3
Remove the memory cover. Unscrew the eight screws holding the memory board in place; this cover is located above the Gateway product sticker. 4
Disconnect the Wi-Fi adaptor. Remove the Wi-Fi cover by unscrewing the single screw holding the Wi-Fi adapter in place; this is located directly above the hard drive. Remove the two cables connecting the wireless card to the adapter and snap the card out of the holder. 5
Remove the memory modules. Gateway computers typically have two memory modules located in the center of the motherboard; lift these out gently with your fingers and set them aside. 6
Release the heat sink. Unscrew the four screws around the heat sink assembly; this unit is located to the left of the ventilation fan and is surrounded by a copper base. Carefully lift the heat sink and the cooling fan off the unit and unplug the cable attaching it. 7
Remove the CD/DVD drive. Unscrew the small screw located to the left of the CD/DVD drive, then push the drive out to remove it from the laptop completely. 8
Remove all screws around the base of the laptop. You will now be left with a total of 18 screws located around the edge of the base of the laptop, and in between the stickers and hardware components in the center. Remove all of these carefully and set aside in a safe place. 9
Prepare the cover for removal. Turn the laptop up on its edge so that the back of the laptop is facing you; you will see two screws on the hinges of the computer. Unscrew these and set them aside. 10
Remove the hinge cover. Open the laptop so that the screen is laying flat; use the flathead screwdriver to pry open the hinge cover and pull it off gently with your fingers. 11
Remove the keyboard. Lift up the keyboard and reach behind it to release the cable. You will need to tug gently on the cable to unhook it from the motherboard. 12
Unhook the LCD screen from the notebook. Unplug the Wi-Fi antenna cables located on the right side of the motherboard directly under the screen, then unplug the video cable located directly under the hinge cover. Remove the pair of screws located to the left and right of the LCD screen and gently lift the LCD screen off the notebook's base unit. 13
Remove the system board. Turn the base unit over and unscrew the five screws securing the motherboard to the base. Two of these are located near the hinge cover, and two are located beneath and to the right of the hard drive unit. The fifth is located a few inches below the top right edge of the laptop. 14
Disconnect the motherboard. Lift the system board, then unhook the cable connecting it to the base unit.
Not a perfect fix, but this is what I did: There are 2 spring-loaded pistons located on the printer side of the hinge that cause this problem. I think there should be another piece of plastic that holds the top of the printer hinge down on these springs, but when this hinge is gone, the top of the printer is held upward by them. If you use some pliers to gently pull these spring-loaded pistons upward, you can easily pull them out, followed by the springs they cover. Once removing these, the top of the printer lies flat. The top is still unstable, but mine will now feed paper just fine and closes. Hope this helps! WebRepOverall ratingThis site has no rating(not enough votes)
Turn off the printer and unplug the unit. Remove the following doors: the DIMM cover, rear cover and top cover.
Open the door to the area housing the toner and remove the toner cartridge. Set it aside. Release the toner drive arm located at the right side of the toner door.
Locate and remove the screws at the front left and right corners on the top of the printer and the two screws at the right and left at the top of the back of the printer.
Locate the latch at the left side of the hinge for the toner door. Release this latch and then remove the door.
Pull out the old pickup roller and replace it with the new tray 1 pickup roller. Reassemble the printer.
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here... ETB removal and replacement Use the following procedure to remove the ETB (RM1–1881–000CN). 1. Remove or slightly pull out Tray 2 (RM1–1916–000CN). 2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover assembly. 3. Open the front door. 4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers outward to remove. NOTE : To make the removal of the right cover assembly easier, release the tab on the inside of the cover. 5. Remove the left cover. 6. Squeeze the white link lever on the left side. 7. Remove the screw on the right white plastic catch, and then remove the plastic catch. 8. Close the ETB. 9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by carefully snapping it out of place. 10. Remove one (1) grounding screw from the ETB harness. 11. Pull out the white wire holder by pushing it up. 12. Pull out the ETB connector. 13. Remove one (1) screw from each hinge cam on both sides. 14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge cam (RC1–5311–000CN). 15. Remove the ETB.
Use the following procedure to replace the ETB. 1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left side. 2. Complete replacement by following steps 1 through 14 above in reverse order. NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover and lower edge of the face-down cover with their respective slots.
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Yes, I had the same problem in Sept 2006 - a broken left hinge that needed fixing. Ordering the part was easy. I was able to install it myself, but it required some attention to detail.
I called Brother International at 800-284-4357, Option 1, then 2. I ordered the left hinge - Part No: LP-2403001 - described as ADF Hinge Assembly (left). If you broke the right hinge, the part number may differ slightly, but person on phone should be able to assist. It cost me $11.55 including shipping.
