2003 Jaguar S-Type Logo
Posted on Sep 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine system fault,park brake fault
Engine system fault, park brake fault & dsc not avilable lights were flashing which caused the car to completly loose power. could this be a recall problem?
  • thomrealest Sep 04, 2009
    Thank you for your experties... wow that worked!!!! you are a god sent.
Anonymous
Level 3:
Brigadier General:
  • Master 5,158 Answers
  • Posted on Sep 04, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
5158
Questions
5
Helped
2065885
Points
15105
4 recalls so far. http://www.motortrend.com/cars/2003/jaguar/s_type/recalls/index.html
unhook the battery for about 15 minutes, that will reset the computer. if you have an anti-theft radio. make sure you know the code first.
1 Related Answer
Anonymous
  • Posted on Sep 27, 2009
SOURCE: Engine system fault,park brake faultengine system
how do i fix or reset this fault
Engine system fault,park brake faultengine system fault, park brake fault & dsc not avilable
WHY PARKING BREAK DEFAULT LIGHT 2004 XJ8 ?
if the park brake warning is on and the park brake is inop. there are several common problems with this system, the most likely causes are 1 the rear brake caliper sliders are part siezed or the pads siezed in the caliper frame 2 the wiring to the park brake motor open circuit or rubbed through on the rear subframe.3 the park brake motor has failed, you really needto get the fault codes out of the park brake module if the above checks out ok the above faults i have found to be the cause 9 out of 10 times. hope this helps.
Parking brake not available? "check parking breake system lights, what is the problem??
When you have the vehicle checked for codes
& the Parking Brake System tested ,you will have your answer
Obviously there is a system fault eg: it isn't working correctly or
at all
Please help: "DSC not available, Gearbox Fault, ABS fault, park brake fault" 2003 S-type
In order to help you I would need the contro system read for fault codes and go from there.
2004 Jaguar s type dsc and parking brake along with engine system fault comes on and car goes into limp mode when slowing down or when it rains.
I had the same thing here, I paid lots of money to find out what is the problem, mechanics played with my poor car damaged everything they can to stop it from running, but when I found out that when I changed the battery on my own, with a turkish manufactured battery of 100 A big battery, not even the fault stopped appearing but all the car was boosted in performance, Dsc not available and Park Brake is all related to the level of electricity running the parts of car was screaming back to you, change my battery, all parts of Jaguar runs on electricity, main computer now runs faster, no delay on screen, and now Dsc not available once ignited doesn't appear anymore, remember that once car is reset by battery change, you need to apply brake and boot (step on brak and hold park brak lever up at the same time with pressing computer button on stearing whisk for like 10 sec until you see on screen AVE back again), and bypass radio lock by pressing on the three buttons, mem and the right combination with >>, and you're set
2002 jaguary x type dcs light stays on, what is this
First check your park brake and Dsc (skid control) if they work then forget, see the lights on the dash. Could be low pad, sensor fault etc but most likely not the problem. The engine system fault is the most likely area to look. Obviously check the usual fluids, oils etc.
Also check here, its a Jaguar forum with a lot of information for you.
http://jaguarforums.com/forum/showthread.php?t=13153
9helpful
4answers
Parking Brake Fault light is coming on? I reset the battery and it keeps coming on. It starts with the "apply parking brake" light and then when you take off, it goes to a parking brake fault? Please...
This is a common fault often caused by low battery voltage, before you start taking expensive actions with the park brake modules etc get your battery checked for 100% efficiency.
Hope this helps, good luck.
2helpful
Renault laguna 1.9 dti, 2000 'v' reg, old shape estate. Indicators flash at double time when braking. Fog light lights up on dash when braking. If lights are on a night and you indicate, all the lights do...
Your problem is you have a bad connection somewhere like at parking lights/stoplights/rear lights/so what you do is remove all parking and rear lights then turn on indecators and check the lightsyou will find that one of them has a bad earth and when you put them back in the lights flash dimmly and thats the one with a bad connection or a bad earth going to that light.
Let me know if you still have a problem Ron
17helpful
2answers
Engine system fault,park brake faultengine system fault, park brake fault & dsc not avilable lights were flashing which caused the car to completly loose power.
ABS & park brake lights come on after about 10 min. of hwy drivin
there is a problem with your abs sensor ....sounds like the sensor is applying the breaks for you when it shouldn't ....have a mech. look at it ...the e- brake issue could be causing a fault in the system ....all the symptoms may be the car.s computer,s way of telling you there is a problem "please bring me in "
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
