Televison & Video Logo
Anonymous Posted on Sep 04, 2009
I have the Sylvania TV model#SST4191. I can not get an universal remote to program with it. Isn't there a sensor on the TV somewhere to read the code?
matt martin
Level 3:
  • Televison & ... Master 1,259 Answers
  • Posted on Sep 04, 2009
matt martin
Level 3:
Answers
1259
Questions
12
Helped
297432
Points
3635
I dont know this model or how old it is. If it is an older set a universal magnavox or philips remote will work. You should find an older model remote in this case. If it is a newer tv you may use a newer magnavox or philips universal remote. If this is a flat screen, you will have to contact the manufacturer. You will be pleased to know now, that you are on the correct path.
Testimonial: "Thank you for the information. I will try this."
2answers
Need to program my phillips universal remote CL035A to my Sylvania TV
Look in the manual of your
Phillips universal remote CL035A for ther listing of TV codes, take notes of codes for Sylvania and input codes accordig to instructions of your manual.
If you can locate Sylamia, follow instrucions for unspecified device.
You don't have a manual?
How to Program Philips Remote Control Without the Codes eHow
I have a Sylvania 6424FF tv and i cant get it programmed to a univeral RCA remote the codes listed are NOT working
Hello
RCA- RCU 500 model universal remote has Sylvania TV coded with. The codes are:
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
Universal remote has lost it programming and wil not operate tv. I need codes and to know how to enter them into the remote.The tv is a SylvaniaModel 6424TF Please respond. Thanks you Pauline
Hi, I have a few things for you to try.
1. Your TV "6424TF" seems to have problems with its IR "Infra-red" sensor going bad. This is a common problem with your model TV. If this is the case no remotes will work on your TV.
2. Because I do not know the model of your universal RCA remote I cannot tell you how to program it.. please supply the model number of it. Try looking under the battery cover. might be an "RCR..." number. I need to know this because all universal remotes have different codes and programming methods.
3. To know 100% if its your TV that's bad you will need the original remote for your TV. I have already looked up your original remote and you can purchase a brand new replacement that will work right out of the package (assuming your TV IR sensor isn't broke) here: RR0108UD for all sylvania TVs . no programming is necessary for this remote.
I need to know a universal remote control code for sylvania tv's
try programing it with a Funai tv codes
Funai is the company that made your set let me know
How to set up to control TV ?
i have a one for all 3220 remote and i do not have the direcntions on how to program a sylvania sst4191 i think i have found the code
Cant program my universal remote
Search the model # of the REMOTE on www.google.com and a good portion of the manufactures have the Codes on thier sites for you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
