2003 Yamaha YZ 125 Logo
Posted on Sep 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1998 yamaha yz 125. Gut did a top end rebuild. All works fine, but leaking coolant thru the weep hole just under the inpeller cover. What is going on here?
Anonymous
Level 3:
President:
  • Yamaha Master 2,050 Answers
  • Posted on Sep 04, 2009
Anonymous
Yamaha Master
Level 3:
President:
Answers
2050
Questions
0
Helped
710353
Points
6446
It has seals there for the water pump. They need to be replaced.
2006 yz450f coolant leak water pump weep hole
Take compressed air and blow air up into the the weep hole. For some odd reason it made 3 different CRF's stop leaking. It's worth a shot.
3helpful
3answers
2004 YZ 250 is leaking fluid out of the hole just behind water pump underneath the crankcase. The gasket looks fine and its not leaking from the gasket its actually coming out of the hole. I started...
The hole is a weep hole, designed to drain coolant from water pump seal leakage or oil from bearing seal leakage from contaminating either system. So one of the seals is leaking, and you should rebuild the pump.
Looking at the parts diagram it appears the impeller is threaded onto the shaft on the YZ250....hope that helps, heres the parts diagram
http://www.mrcycles.com/fiche_section_detail.asp?section=50188&category=Motorcycles&make=YAMAHA&year=2004&fveh=1236
Yz 125 2001. starting ploblem after top end rebuild
Kinda sounds like your needle valve is sticking in your carb and it is giving it to much fuel
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
