Driver side window doesnt go up and the other three only work with the middle concel button
MY CAUTION LIGHT KEEPS FLASHING ON MY DASH BOARD
Hi, This is usually just a case of a replacement switch that is approx £12-£15 from an Audi dealer. I had the same issue and this fixed it.
I had this same problem in my 1997 Audi Cabriolet. You need to find the power window module under the dashboard near the steering wheel. It's a small plug in box about the size of a cigaratte pack. Take out the module and pry the plastic case off. Then inspect all the solders on the circuit board. I found a broken solder joint, re-did it and it works perfectly. The dealer wanted $500.00 for just the part.
