SOURCE: Upper and Lower Looper Rub Together!!
Your loopers need adjusting, impossible to explain how to do this, you need to be shown. Can I suggest you contact a sewing machine tech, sure it will cost but if he is a decent guy he will show you how to adjust the machine.
SOURCE: I need to check the tension on my Janome 534D, I
Here's a couple of solutions to try.
* Re-thread your machine
It may be threaded incorrectly. And when you re-thread it, make sure your thread goes in between your tension disks. (If you don’t know where your tension disks are, consult your machine’s manual.)
* Check your tension disks for dirt or lint
Lint or dirt between your tension disks may be keeping your tension from working properly. Clean out any you find.
I hope this helps.
SOURCE: adjusting lower/upper looper tension
Clean in between you tension plates of your tension units and rethread making sure your cotton runs between the tesion discs.
SOURCE: white speedylock 7340 loose/missing stitches, up.looper unthreads
All tensions should be on 4. Also, make sure the threading is done correctly. Or if you wish; You can contact me on other sergers for sale. "Best prices guaranteed"! [email protected]
