Question about Exercise & Fitness
Neighbor gave me the treadmill and it was working so when we moved it now it want come on . Help
2 Suggested Answers
SOURCE:
  • 34 Answers
SOURCE: belt is all the way
To get the belt to the center you will see two adjustment bolts on the very back of the machine that require an allen wrench to adjust. Whichever side the belt is going towards is the side you will need to tighten. The best way to do it is to turn it a half of a turn then try and run the machine. if that does not help then loosen the other side a half turn, continuing until it pulls that belt back to the middle.
Posted on Aug 12, 2010
Pls I need to repear my d c motor.118-1, thanks
Sorry but we need much more inforoamtuion than you gave, part numbers or models numbers are no help[ at all.
Sep 01, 2013 | Exercise & Fitness
The washer won't start.
you must need to check the motor first if still working. you can directly plug the motor to the ac outlet to ensure if still good. if still good you can check the wiring, look at the wiring diagram post inside at the back portion of the cover serve as your guide.
Oct 12, 2012 | Frigidaire Washing Machines
The clock keeps counting down and it stops. the store where I bought it has closed and/or moved from my area. please help me with an address/phone and solution.
you need to change the settings on the treadmill. you probably have it set to stay on and work for a set period of time. try going through the settings menu. if you need additional help, consult the manual. should be available online. if you gave me the exact make and model of the treadmill, i may be able to find a downloadable version for you
Aug 12, 2011 | Exercise & Fitness
I recently got a free Nordictrac NTL1095.0 C2050 from my neighbor. it seems to be stuck in demo mode. no buttons work even when trying to get out of said mode. The console will beep when key is put in but...
well the reed switch is working but sounds like board or both check voltage coming to the console. wire harness. not sure but if it reads low controller iisue
Mar 16, 2011 | NordicTrack Exercise & Fitness
Belt is all the way over to the right instead of in the center. belt wont move. I hear motor running. How do I get the belt to the center. A neighbor gave me this treadmill with no manual. It worked for a...
Aug 12, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Won't turn on at all.
If you have no lights, check the main harness that cary power to the console. Check connection at both ends.
PS Always check outlet to make ssure you have 120 volts.
Jul 24, 2009 | Exercise & Fitness
Need to get the phone unlocked
call ur neighbor if u no fone #. ask her/him what there fone# was. enter last 4 digits of that # and that should b it
Apr 24, 2009 | LG enV VX9900 Cellular Phone
Exercise & Fitness Logo
19 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
