Ok, that only happens when there is something blocking the signal to your Wii's antenna. Try moving the balance board further away from the television.
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
The trick to hula-hooping is timing. If you get the hoop moving fast on its initial turn around your midriff you have a better chance of getting the timing- I like to use my legs to get the hula just right... And remember- the slower the body moves on the timing, the faster the hoop hulas.
If you're not shifting enough weight to one side, you can't catch a hoop. I have found that lifting the opposite foot off the board as soon as the toss is thrown helps quite a bit.
If you're still having trouble, evaluate how the board works with other activities on WiiFit. If you notice problems in other areas, you may have a defective unit. There is a calibration feature on the program, and if that doesn't work, try opening up a trouble ticket on www.nintendo.com.
No it is not how Wii Fit is supposed to be. First, let me suggest that you ensure that the power button on the Wii Fit Balance Board is facing AWAY from the TV set. This may seem silly, but it's the most common error. As for the Hula Hoop game, make sure that your weight is all on the side of the Wii Fit Balance Board in the direction that you need to lean to catch the hoop.
There have been instances of the sensors in the Wii Fit Balance Board going out. If you have tried the above steps and you are still getting errors, please go to www.nintendo.com, register your product, and open a problem ticket with them.
Did you buy it new? If so, it can sometimes play a few tricks. What I do, is restart the Wii, Go to start either the disc channel Wii Fit, or the Wii Fit channel. Do either the body test, then do it again straight after. Test it now, it should come up as all working. If not, you may have to ring Nintendo.
