Question about The Audio Players & Recorders
How to reset DVD digital cinema system TH-P3. the system goes suddenly in stand by mode when trying power on...
SOURCE:
SOURCE: JVC TH-A5R DVD DIGITAL CINEMA SYSTEM
I found the solution for my DVD player you need to hold source down for 5 seconds which will unlock the disc.
Posted on Apr 01, 2008
SOURCE: Tray locked
Dear friends,
I have solve the problem.power off the player and press and hold STOP+OPEN,CLOSE button.and than power on the player than display shows unlocked.the problem solved.and enjoy
Posted on Mar 25, 2009
SOURCE: NO SOUND From JVC TH-S5 Home cinema system
I know this is an old topic however someone somewhere might benefit from this feedback. I purchased the JVC TH-S5 service manuals from ManualsParadise.com and after metering all the supplies as 'OK', I then focused in on the 'common' lines associated with the two onboard power amps IC's (STK413-400) and found that they were missing a bias supply. This is derived from the onboard 40v Supply 'dropped' down by a 47 ohm resistor R2702 (rated 1/4 watt but advised to make this at least 1/2 watt). The resistor was found to be open circuit i.e. a very high ohmic value. Looking at the circuit diagram again, I would feel that this is going to be a common issue with this unit.
Mike.The.Cork
Posted on Sep 12, 2009
  • 5 Answers
SOURCE: not getting any power
Probably a blown fuse. If you have a warranty or can return it do that, if not unplug it, open it up and there should be a 250 volt glass type fuse. pull it out and make sure it is blown. If it is replace it at radio shack. If it isnt check for loose wires around the power cable and the transformer.
Posted on Feb 27, 2010
SOURCE: unlock code for jvc dvd
hi if you can help me i have a dvd jvc th-a35 and it wont play all the dvds what is the number or how i can unlock to play all dvds
Posted on Jul 24, 2010
I have a jvc digital cinema system TH-U1. i can get sound from the dvd, radio and usb but i cannot get sound from the tv mode can you explain what i have to do please
If you are using some kind of a receiver try to check the cable specially the input, output connection to your tv and receiver. Hope that this may help.
Jul 11, 2011 | JVC Televison & Video
I have a (jvc dvd digital cinema system th-s3). that will not play original dvds however it seems to play copies and cds just fine in fact all other functions work correctly. i have tried a lens cleaning...
I have the same system. I've had no trouble until a year ago, then the system got particular about when it wanted to play DVDs. I've also used lens cleaner to no avail. It plays some DVD's but plays all CD's and some copies. It has given me good service but cost me a lot of money. I hope there is a simple solution to this.
May 17, 2011 | JVC TH-S3 System
We have JVC DVD Digital Cinema System Model TH-A9. We enjoy elethe set and have many hours per day playing with the DVD music as well as the movies. Suddenly, our powered sub-woofer Model SP-PWA9 fails to...
It sounds to me that the sub has blown a fuse. This could be caused by a faulty amp. Subwoofers are at the end of the day are just a mono amp. If the main amp in it shorts, it will blow the fuse.
A visual test might be all that is needed, plus your nose if it has fried the part!
Jun 11, 2017 | JVC TH-A9 System
Connecting TV, cable decoder and xr29m80
you have two choices. a newer connection you must have on both devices is a optical connection. if you have this buy a digital optic cable.
if you dont have this connection. look for a red and white connection on both devices this is just a simple audio lead .
To recieve the sound through the speakers after you have installed the leads make sure the home cinema function is set to "tv"
Aug 07, 2009 | Sony FD Trinitron WEGA KV-XR29M80 TV
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Philipe home cinema - No Disk Error
Hi, the best thing to do is to reset the device back to factoy settings, how to do that is mostly written in your manual. Also unplugging the power for 5 to 10 minutes might help.
Aug 07, 2008 | GE MA90559 Rear Speaker
DVD player do not turn on
My JBL Cinema ProPack 600 System is stuck in stand bye mode (amber light). Anybody know how to resolve this problem?
Feb 15, 2008 | JBL Cinema ProPack 600 System
Th-R1 no pwoer to subwoofer - transformer u/s?
my power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Oct 14, 2007 | Audio Players & Recorders
16 people viewed this question
Top The Audio Players & Recorders Experts
stephen Kiarie
stephen Kiarie
Level 1 Expert
Roy Cunningham
Level 1 Expert
meowwl
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
