Linksys Wireless-G Broadband Router Logo
Posted on Dec 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Failed to detect an internet connection
I just bought a router in order to operate wireless laptop at home. The router installed well to my fix PC through the attached cd software. Now I'm trying to connect the laptop. EasyLink Advisor has established a wireless connection to the router, but failed to detect an internet connection. Why the PC connected to internet and the laptop cannot???
  • 9 more comments
  • Anonymous Dec 08, 2007
    Gateway laptop with realtek wireless
    turned off radio (Fn+F2) and when I turned it back on could not connect. Windows Vista doesn't detect the wireless anymore. Checked wireless is on. Reset router. Another laptop detects and connects through wireless. Used manage wireless to make sure everything is there. Updated driver from internet. Ran diagnostics - finds no problem. Checked hardware - says working properly.
  • Anonymous Dec 12, 2007
    my laptop connects to the internet but my desktop wont. i have them both connected to the router
  • jz7443 Dec 16, 2007
    My laptop connot detect any wireless device
  • Anonymous Dec 18, 2007
    i cant figure out
    i need to know were the blue wire goes
  • Robvya Dec 24, 2007
    I have 2 desktop computers and two laptop in my house, which all have Internet connections through a Linksys Wireless router. Both my desktop computers are wired up, and the Internet connection is working fine. My laptop is using wireless, and that was working perfectly normal until three day ago. I got a message on the laptop saying that "No wireless networks were found in range" or "Wireless connection unplugged", or something like that.
    I always put the wireless connection switch on. and ive tried to reset the modem and linksys several time
    My router is working fine, and the "Wireless connectivity" sign is green,
    When I searched for all wireless networks in range, my laptop would detect my neighbours networks and mine, but now, i can only detect my neighbours networks.
    my laptop is a Acer 9300-5197 with wireless card built-in and the model of the card is atheros AR5005G and the second one is a cicero notebook and model card is PRO/Wireless LAN 2100 3B Mini PCI Adapter.
    By the way i have a linksys router WRT54G ( bought new 1 month ago ) and a speedstream modem i think
  • Anonymous Jun 30, 2008
    Wireless availability icon, but will not connect to internet.
    Followed directions for wireless set-up thru Dell and thru Linksys
    Neither works
    Also (need to know) - Does security play a part in installation?
    Do computers arrive with installed wireless cards previously activated or is there an activation process separate from the wireless installation?
  • hwany141 Dec 25, 2008
    I have two laptop computers and I am trying to use the Wireless G Router to connect to the internet. I have a Greyfox router that connects to a modem for my DSL internet access. Am able to connect to internet via hardware. Both laptops recognize the wireless router signal and connect to router but not able to access internet. There was a time when I was able to use wireless router.
  • michi1993 Feb 28, 2009
    i got all right but the psp said that theres a internet failed
  • urmoron Apr 21, 2009
    Even is connected to internet, the service failed to detect the connection status Also the networking & sharing centre been disabled It all happened after I installed the ERRORFIX programme The problems remained after the uninstallation of the program
    Can you kindly help me to solve these problems
    Many thanks
  • Anonymous Mar 25, 2014
    my laptop wont connect to internet on wireless connection but other laptops connect to the same one no problems
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 21, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2214
Points
If you are having problems with your Linksys routers, reset the router and configure it again. In configuring the router, I suggest that you use the online tool that will automatically configure your router. It is similar with the setup cd but the online tool works better. The reason why the setup cd fails is that it has its own bugs. So just use the online tool. You can get the online tool on this website--www.linksys.com/easy.
Cory Kielion
Level 2:
Sergeant:
Novelist:
  • Expert 143 Answers
  • Posted on Dec 07, 2007
Cory Kielion
Expert
Level 2:
Sergeant:
Novelist:
Answers
143
Questions
0
Helped
136276
Points
516
I don't recommend using the software as most of the time, it either prevents a connection to the router or a connection to the internet. Sometimes both. (I've seen it.)
Instead, use Windows XP's built-in Wireless Zero Configuration (Or use Vista's built-in wireless network detection.) As long as your drivers for your wi-fi adapter are properly installed, you shouldn't have problems using the built-in connection methods.
As for the software... All it's really there to do is help you to bypass the default security of the router in order to get initially connected. I've found the software to be nothing but troublesome in the long-run.
My recommendation is to remove the Linksys software. If you are not able to connect to the router after that, use an ethernet cable to attach the PC to the router so that you can configure the router. Set up wireless security that way.
Once you have configured the wireless security, you should know what your encryption key is. (Write it down for yourself.) Use the built-in wi-fi configuration tools in Windows to seek out the wireless router and connect to it. Type in your key when asked for it and you shouldn't have any problems.
You may consider using the RESET button on the back of the router if you continue to have issues.
One other problem I've often run into is using DSL with the Linksys WRT54G routers. Some DSL modems just aren't compatible with the WRT54G routers. Primarily the older DSL modems.
For example... I had a client recently who had bought the WRT54GS router. He just could NOT get it connected to his DSL modem. Even using the Linksys software. It just wouldn't use the router as a legit gateway device. (He was connected by ethernet and could get into the router's config interface.)
I eventually advised him to contact Qwest and have them send him a much newer version of their DSL modems. (The one he had was a DINOSAUR.) They sent him a new one. Once he got the newer one, we were able to get it networked right away. WITHOUT any extra software. Just using Windows.
Also be sure to check the configuration of your wi-fi adapter in your laptop. Make sure that it is not configured with an old configuration and is set to automatically get an IP from your router. Don't use a static IP while trying to troubleshoot your problem. Let the router configure the IP of your laptop for you. It could just be something as simple as the DNS servers aren't configured properly. (You can find your internet IP and DNS servers in the router's status page, by the way.)
Let me know if you have more details that would be relevant to the situation.
  • 1 more comment
  • Cory Kielion
    Cory Kielion Dec 07, 2007
    One thing to mention...
    Windows keeps a list of wireless networks that you have previously connected to. I would try clearing that list by removing all entries. (You'll have to do it one at a time.)
    Those entries have prevented me from obtaining a connection on several occasions. Especially if the list contains the name of a router that I've connected to before - and the name of that router is the same as the router you are currently connecting to.
    Click HERE for a picture showing the list of access points. Use the "Remove" function to clear the list.
    Click HERE for a nicely-done site that helps you to troubleshoot wireless networking. (It has plenty of details. Half of which you may not need to worry about...but it's useful anyway.)
  • Cory Kielion
    Cory Kielion Dec 08, 2007
    Your rating of this post is unreasonable as I DID leave the solution open-ended. You were supposed to continue communicating with me to let me know what you try and what the results were.
    There really isn't much more information to go over pertaining to your situation. I gave you pretty much all that there is - considering you didn't really tell us much more to work with. (Such as what you did with the software, what your network settings were, etc.)
    You CAN NOT come to this site and expect everything to be solved in ONE post. You HAVE to continue communicating with us in order to reach a resolution. Please understand this in the future!
  • Cory Kielion
    To GUEST:
    Read my previous post here. Check into that list of Wireless routers
    that Windows keeps. Vista has it, too. Delete all entries from that
    list and REBOOT the machine.
    Vista in particular seems to have an issue with being
    connected...losing connection then NOT BEING ABLE TO RECONNECT when you
    try to.
    Clearing that list and rebooting fixes the issue for several of my own
    personal clients here in my local area. It's a Vista issue from what I
    can tell.
    Cyryl
2helpful
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
3answers
Dell INspiron 7500 laptop
yes of course you are correct, to make this laptop, go onbline wirelss, yoy need to get a wireless router..
My new Lenovo G550 laptop (bought 3 days ago) won't connect to a wireless network anywhere. At home I have a desktop and another laptop that are connected and I don't have any trouble with them until I...
The wireless card may be swithed offGo to control panel and select "wireless connection" windows will detect the wireless card and tell you if it's swithed off.
Cant connect to the internet using wireless modem
Hi. Were you able to detect the wireless router? Make sure also that wireless card driver is installed in your computer in order to connect to your router. Make sure also that you are entering the correct password of your router when you are trying to connect to it.
Toshiba NB 205 connects to router but not internet
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
1helpful
Acer Aspire Computer
Hi there.
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Bought a toshiba satel laptop and want to router it to dell dimen
You don't need a router for the laptop it has a wireless card in it already, buy a router for your home PC and I would buy a linksys with cap 5 network cables and wireless connections so you can use the printer off of the home computer PC. If you have high speed Internet you can request for a router for free with a wireless and cap 5-cable capacity.
Windows xp service pack3 no wireless internet
ok, this is an easy fix, just go into device manager and unistall the wireless card, dissable AVG firewall and activate microsoft's firewall. Then Download CCleaner and clean the registry, you can download it from here:
http://www.filehippo.com/download_ccleaner/
when you have cleaned the registry restart the pc, it should now detect the wireless card and install the drivers for it, it will show this in the system tray (bottom righthand side where the time is)
This should resolve the problem for you
post back if you still have problems
regards and please remember to rate us
The Fixya Team
Laptop won't detect wireless connection (but does detect others)
Dearest crystal 7, you prombally need to reset your windows
wireless. go to add and remove and remove the wireless
drivers the reboot your computer and the reinstall your wireless driver ,then go to the control panel go to internet options then to connetions then scrow down to lan settings the put a check in atuomatically detect settings the apply then ok . the reboot your computer then set up your wireless for connections for your house and it should work ...... lala linda
2answers
Belkin setup
Normally, connect pc with router, and modem off. Turn on the desktop and then turn on the modem and router. letting the modem and router assign ip addresses to all connected devices.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
