SOURCE: phono input
I am not really familar with this receiver but almost all phonograph must go into a phono in. Due to the fact that a phonograph does not have whats called a pre amplifier. generally the receivers have a phono in and that input has an more sensitive amplifier cicuit in the input. That is why if you plug it in to something else unless it has a preamplifier the sound will be real soft. I think Radio Shack sells a amplifier you plug the Phonograph into one side and the other side into the receiver then you can use any input you choose.
SOURCE: STR-DE545 Receiver -
Turn the reciever off. Count to 9 slowly. Press the setup button and power on at the same time.let t run its demo. Turn the power off. count to 8 slowly. Turn the reciever back on. Porblem solved?
SOURCE: How do I hook up my Bose 901s to my Sony Receiver
look at your speaker wire there should be some marking the distinguishes each wire. You need to get this right make sure the negative or black color from the speaker is connected to a negative or black of the receiver. ditto for the positive (red). look on the back of the receiver you should see where the speakers get connected left, right.
SOURCE: Where can I get the schematics for the Sony
I am not aware of these being available on the web for free. There are sites from which they can be purchased. If you can describe the problem you are trying to solve, perhaps we can assist without the need for purchasing the manual. Please update this with the problem.
Thanks,
Dan
Ok go to this site and about 3/4 the way down you will find your model number... the model numbers are in order so just keep an eye on them as you scroll down...
http://www.schematicfanatic.com/samscit/sony.htm
just copy and paste into your browser
No sound or only a very low-level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see pages 28-30).
>>> Adjust the speaker volume (see page 19).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 17).
