SOURCE: "Toner Low" message = no faxes :(
Need to do a hard reset. Contact Dell for instructions, but it will involve turning printer off, opening front cover, pushing buttons on front panel in certain sequence, etc. Each model differs, which is why you should call Dell.
SOURCE: Jura Capress Impressa E8
Open the drawer and take out the box for the grounds. Run a rinse cycle and it should now go back into place.
SOURCE: Decalcify
when the machine gives the signal press the bottom right hand button for 5 seconds.
it will tell you to open the knob.
before you open the knob fill the water tank with the descaling solution
place a large water receptacle under the steam wand.
now turn your knob
the machine will start to descale this can take a while
when the descale cycle is finished close the knob.
rinse the water tank out with fresh water and fill it will clean drinking water.
Press the same button on the bottom right to confirm that yo are doing the rinse cycle.
open with knob and the machine will start the rinse cycle.
when the rinse cycle is complete close the knob and load the circuit.
when descaling is over fit a new cartridge filter in your water tank and off you go with your descaled cleaned coffee machine.
SOURCE: keep getting "decalcify" message
Go to MENU and scroll down and find SIGNAL DESCALING. Select ENTER the machine will ask RESET , YES or NO. Select YES and ENTER.
