Solution for ricoh 270, error 546
SOURCE: My Rico Aficio 200
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
SOURCE: RICO AFICIO 6010 KEEPS PAPER JAMMING,AND THE RIP
The Rip needs the system software reinstalled. The jamming could be anything, need more info.
SOURCE: eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
SOURCE: AN SC547 ERROR ON MY
547 D Zero cross error § The zero cross signal is detected three times even though the heater relay is off when turning on the main power. § The zero cross signal is not detected for 2 seconds even though the heater relay is on after turning on the main power or closing the front door. § The detection error occurs twice or more in the 11 zero cross signal detections. This error is defined when the detected zero cross signal is less than 45. § Defective fusing lamp relay § Defective fusing lamp relay circuit § Unstable power supply 1. Check the power supply source. 2. Replace the PSU
Hi theodory jeremia dizange, I want to help you with your question, but I need more information from you.
Please Call Customer Service & Support For Help Call 1 8O5*465*751O Toll Free 24x7
