My name is Mimi from Nigeria
A printer it is, had to google it and read you manual for you.
no PC stated, (fail)
the printer was made in 2000 -2002, 19 long years ago.
did it print ok for 17 years and just fail today or found this in a garage sale? yesterday.?
Id say there are like zero printers this old working today.
H4 00 is heat roller failure, stated in your manual;
if you google for the manual, it covers this in the users guide.
pasted.
H4
00
Heat roller low temperature detection
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
SOURCE: Error on Sharp AR-168D Copier
The manual says to turn off and unplug the machine and wait for 10 seconds. Then plug it back in and turn it on. If this doesn't get rid of the problem contact your sharp dealer/service man.
SOURCE: I am using Sharp AR-M201 photo copier machine. I
F2 -02 Toner supply failure - Toner supply abnormality caused by
cause :-
- developer unit trouble
installation of unpacked toner cartridge
