Firstly u should need to copy files from pc to mobile or download games from internet through mobile open the application through file manager nd install it ...
Note After you insert the disc, the default action is to automatically start the game. If this happens, exit the game and return to the Xbox Dashboard.
Insert the game disc into the disc drive.
From the Home hub, select the game in the drive tray, and then press X on your controller.
Select Install.
A progress indicator appears while your game is being installed on your hard drive.
Note Installing an Xbox 360 game might take 12 minutes.
that means ,the games which u have installed are expired ,,u hav to instal new version of that games ,,or else that games must be hacked version games u cann't instal them in your phone
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc
Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
From the Xbox Dashboard, go to My Xbox.
Select the game you want to install.
Press Y on your controller.
Select Install to Hard Drive.
Notes
Installing an Xbox 360 game might take several minutes.
Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
Go to My Xbox, and select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
You specify the xbox 360 do you know what year model you have? If it as earlier model then likely you are running into system instability with many reasons for the error being possible.
Does the error only appear with one particular title or across your game library?
If it is just one game then attempt to install the game onto your hard drive and play the game after that. To install the game onto your hard drive you will need to do the following:
Notes
I have c3300k. If i want to install a games, appears a message "Memory
full, delete games", but i dont have installed any games. How i clear my
phone memory at the games section? Please help me...
It seems that you can only download games from internet. As soon as you click on java app/game file link in the browser. The Java install options appears and the app/game is installed.
I tried all ways to install games from PC to cellphone. But so far I am unsuccessful.
