JVC AM FM CD DET FACE CAR STEREO Logo
Posted on Sep 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1986 NISSAN 300Z THE STEREO WIRE WERE CUT NEED COLOR CODE PLEASE TRYING TO INSTALLED A FTER MARKET STEREO JVC
Anonymous
Level 2:
Sniper:
  • Expert 69 Answers
  • Posted on Sep 15, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
69
Questions
0
Helped
45534
Points
233
I have attached the wiring info you requested. be sure to test all wires with a meter before connecting. also a link to metra's website if you need an installation kit
http://www.metraonline.com/fitl.aspx
Battery RED/BLACK (+) RADIO HARNESS Accesory BLUE (+) RADIO HARNESS Ground N/A THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS. Illumination RED/YELLOW (+) RADIO HARNESS Dimmer N/A Power Antenna GREEN/BLACK (+) RADIO HARNESS LF Speaker (+) BLUE/WHITE LF Speaker (-) BLUE/YELLOW RF Speaker (+) BROWN RF Speaker (-) BROWN/WHITE LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) PINK
1982 Oldsmobile Delta 88 Royale. The radio is missing and the connector going into the radio has been cut. I need to know where or what the color coded wire are coming from like the speaker or what?
Question edited for clarity.
Question moved to model category.
Your Question posted as an answer to another Post, deleted.
1984-85 Oldsmobile Delta 88 Stereo Wiring - The 12 Volt
the12volt.com https://www.the12volt.com > installbay > stereodetail
1984-85 Oldsmobile Delta 88 car stereo wire colors, functions, and locations.
Missing: 1982 ‎' Show results with: 1982
Oldsmobile Wire Diagrams and Wire Codes
Car Stereo Removal https://www.carstereoremoval.com > htm > WireCodes...
With aftermarket stereo installation? GM Wire Harness Diagram, Wire Color Codes and Pin Configuration, Wire color codes and wire diagrams.
Wiring diagram to replace radio in a 1990 delta 88?
Fixya https://www.fixya.com > Forum > Cars & Trucks
Apr 9, 2009 - Wiring diagram to replace radio in a 1990 delta 88? - Cars & Trucks question.
1986 Oldsmobile Delta 88 Car Stereo Wiring Guide
modifiedlife https://www.modifiedlife.com > 1986-oldsmobile-delt...
Our automotive wiring diagrams allow you to enjoy your new mobile electronics rather than spend countless hours trying to figure out which wires goes to which ...
Need color code for wiring from radio to amplifier on a boss stereo system
factory head end, or not?
if yes, the service manual covers this,
at Nissan or here
$20 paid.. books are not free for sure SM.
https://eautorepair.net/Marketing/Default.asp
2answers
98 Acura cl 3.0 original stereo OEM wires were cut installing aftermarket stereo what are the color codes on the original stock harness so I can route it to the new wiring harness kit
read (you meant main harness to radio sub harness.)
and car may have 5 or more harness for 5 or more very complex radio head end options new,so only the real service manual covers all that for sure,or if lucky 2nd fiddle here.
Hi I'm looking stereo wiring diagram for nissan micra s 2003 to connect new market stereo harness
Hi, you can usually buy a stereo wiring harness that plugs right into your car and they are color coded to match the standard aftermarket wire radio harness, all you do is take the plug from your new stereo and match the wires with the adapter, just connect the matching wire colors. it's super easy and well worth the $15-20, and you don't have to cut up your factory harness.
good luck!
Want to know colors for radio 88 300z sum one cut factory harness
Hope this is what you are looking for and hope it helps....Good luck.
1984-89 Nissan 300ZX Stereo Wiring Constant 12V+ Red/Black Switched 12V+ Blue Ground n/a Illumination Red/Yellow Dimmer n/a Antenna Trigger Green/Black Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Side Shelves Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Need info on wire color coding for jvc car cd player: JVC KD-G140
Try going to the crutchfield website and look for help installing stereo. they can get you vehicle specific wiring codes for free. Also, almost everey stereo has common color codes for wiring. red- switched batt. +, yellow-constant batt. +, black= ground, blue- power anrenna, etc.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_f2436a37cbb50365
6helpful
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
6helpful
3answers
1986 Toyota pickup stereo wiring COLOR CODES NEEDED
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
