I have a Maytag Legacy Series top load washer and the water runs but never fills up the tub.
Make sure the drain hose is not lower than the top of the tub,also check the drain hose to make sure it isn't pushed two feet into the stand pipe or drain it only needs to be about 6 to 10 inches in.
Drain is to low. You will have to raise the drain hose above the top of the washer. Whats happening is the water is siphoning out as fast as it goes in.
Please rate this solution
