Ovens Logo
Posted on Sep 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE Profile oven beeps and displays FO
Oven beeps and FO shows up on display. Push Clear/Off and goes away but then few minutes later beeps and FO.
Anonymous
Level 3:
  • GE Master 3,361 Answers
  • Posted on Sep 02, 2009
Anonymous
GE Master
Level 3:
Answers
3361
Questions
Helped
1029908
Points
10654
Your electronic oven control(clock) is bad and must be replaced.
2answers
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 • GE Ovens
Oven beeps and shows F7.
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
3helpful
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at [email protected] for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
1helpful
F0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
2answers
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
1helpful
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
