2005 Chrysler 300 Logo
Posted on Sep 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 Kia Spectra stuck gear shift
I have a 2002 Kia Spectra. The gear shift will not move out of park unless I override the safety lock, and once I do, I can't shift past reverse. It takes a tremendous amount of effort to move it to reverse, and I can't pull it any further than that.
  • 1 more comment
  • Kaybein Tiara
    Kaybein Tiara Oct 23, 2013
    Its a little black button on your gear sheft when u push it in it should be in not out
  • Anonymous Mar 13, 2014
    What is the drive cycle on a 2002 Kia Spectra to get it to pass inspection
  • Anonymous Mar 30, 2014
    When changing gears to to reverse or drive my kia spectra will not go in gear or move
Anonymous
Level 3:
President:
  • Master 1,392 Answers
  • Posted on Sep 02, 2009
Anonymous
Master
Level 3:
President:
Answers
1392
Questions
0
Helped
657509
Points
4859
Sounds like you need a new shifter assembly, or the brake switch. Most likely will be the shifter though if you can move it out of park with the override.
2005 Hyundai accent gear shift stuck in park after brake failure
Make sure the brake lights are coming on if not the release solenoid that unlocks park gets no power and will not release the shifter from park position. Also check the owner's manual for a possible way to override the solenoid lock.
Fix ya.com
The transmission shift interlock works from the brake light circuits. Check your brake lamps to see if they are working.. If not, fixing the brake lights will get your shifter working. Your Owner's Manual will tell you how to "override" the shift lock so you can get your vehicle in for service.
2002 kia Stuck in Park and wont start
Fix your car right away by clicking the link I attached 2002 kia
2helpful
My car 2001 spectra kia is stuck on Parking it wont move to D. it start and everything seems fine but doesnt want to move from p
check to see if your brake lights are working .if not look for blown fuse or brake light switch or bulbs their should be a override slot or procedure to release from park.release solenoid is not working.
1helpful
My 2002 kia sedona is stuck in park. The gear
shifter cable either broke or came disconnected
2answers
Transmission not shifting into gear
if stuck in park sound like the shift lock solenoid. try moving it with the key turned to the first click. or is it not moving after it is in gear?
1helpful
2answers
Our Kia Spectra was not ran for 2 weeks-when we went to turn on-the gear shift was extremely tight and we used force to move into reverse. We turned the engine off and then when we tried to restart-engine...
this is very common with these cars the shift shaft goes through the aluminum case below the neutral safety switch then is exposed 3 inches befofre it goes into the transmission to shift the case is supposed to be a guide this corrodes you need to use a silicone based lubricant to free it up. Have some one spray under the switch while you hold the brake (key on engine off) and move the shifter from park to first approximately 2 min or thirty times
Shifting gear(Acura Integra 95) gets stuck on P.
The switch should lock the shifter in park . And you should need a key to release it. It is a child safe safety that has been installed since the 70's on all US sold auto's.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
