Irons Logo
Posted on Sep 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DM865 Rowenta Steam Iron auto-off indicator light goes off and on depending on which way the cord is turned or rotated or moved - dosen't seem to stay on.
Anonymous
Level 2:
  • Expert 32 Answers
  • Posted on Sep 03, 2009
Anonymous
Expert
Level 2:
Answers
32
Questions
0
Helped
16171
Points
103
It sounds like a break in the wire, re-wire plug and take about a inch of length off the cable. if the fault is on the iron side it will need taking to a repair shop.
If helpful please tick box
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
288
Points
The circuit board is in the handle and the cord is connected to it you can replace it very simple, when you order the part it come all together and plug in right inside the iron screw your parts back on and you are ready to go no splicing wires the part is about thirty dollars http://smallappliance.com/product.asp?cur=USD&pid=4644
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 • Irons
Rowenta microsteam 400
You need to follow the instructions for the iron. Rowenta make a excellent iron but it's water tank and steam chamber need to be cleaned and rinsed out, say every third use depending on how much you use it. Also, allow the iron to reach FULL TEMPRATURE before you use it.
1helpful
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
1helpful
My rowena precision steam iron steam does not work
Solution for me:
I just bought a Rowenta Precision for $5.95 at Goodwill. I brought it home and it didn't work
I read about the cords and weird size screwdriver needed. It sounds like a lot of work. So what I did was push the electrical cord into the iron. it didn't seem to move but must have. The iron works perfectly now. Such a deal!
Only the green light lights up, dz9080 rowenta advancer iron
A small amount of White vinegar or some diluted dishwasher scale cleaner (calgon) added to the steam water then run it on steam setting ironing some waste fabric untill spotless.
2helpful
2answers
Wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
1helpful
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
8helpful
2answers
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Top Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Iron Expert? Answer questions, earn points and help others
