This msg caused by the Memory problem. Sometimes System can't Accesed the your computer RAM properly or may be your RAM is not giving good performance. pls replace your RAM accordigly..
This could be a memory problem or a problem with the OS (XP). If you can boot the original XP CD like your doing an install then it's not a memory problem more the likely. Can you boot your XP CD?
I'm suspecting you have a bad stick of ram. If you have more then one stick, take each one out individually and see if the problem goes away. If it stops then you know which is the bad stick.
