Tried codes but havent worked,tried seting it up as hisense still nothing, sky remote is version above 4 the exact tv is LCD TV EASYTOUCH 42'' ETL071-42HD, does anyone have any idea what i could do?? thnx :)
I work for Sky. Ive been trying to find the code for you. There are several ways you can do this.
If i could get a picture of what the volume bar on the television looks like, this is one indication to what manufactor made the television.
The other way you can do yourself. Note this will does take some time.
TV
red + select
TV
POWER
repeat the TV , POWER until it turns you tv off. Then press SELECT to save.
The steps I mentioned above. what this is doing is going through all the remote codes on the remote itself. Hense you not inputting any numbers.
As I mentioned it can take 15 - 20 minutes depending on luck. if you get the code early on or not.
Hope this works for you.
Little dish fitter
Easy Touch 42" ET0L71-42HD Sky remote Code 2065
