Question about Samsung Televison & Video
Jumper line to cut on un46eh5000f samsung led tv i do not have a jp852 line
3 Suggested Answers
SOURCE:
  • 10543 Answers
SOURCE: Samsung TV
If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
Posted on Aug 07, 2016
  • 2794 Answers
SOURCE: I have a Samsung un46eh5000f.i replaced all boards and still can only see picture with flashlight. Should I replace led strips?
Before taking the panel apart make sure you are getting the backlight on signal from the main board.
Posted on Jan 19, 2018
Television Samsung Model UN46EH5000F
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Dec 23, 2016 | Samsung Un46eh5000fxza un46eh5000 46 1080p...
Samsung TV
Aug 07, 2016 | Samsung Televison & Video
Samsung UN46EH6050F. Has sound, no picture. Flashlight test shows it has a picture,just very dim. Check voltages on the power supply board,where power goes to LED's and it is reading off the charts
Interesting because the voltage you are reading is for ccfl tubes backlighting but the tv says its led. If you look up the parts though they say the screen is amx and it is lcd. Look at the edge and see if the screen has tubes or chains of leds on strips. LED doesn't fire at 500 it is 130-150 vdc
Jul 16, 2016 | Samsung Remote Control Originally Supplied...
SCREEN FLICKERING
The power supply module in this tv is part number BN44-00341A,
Samsung's dealer info says to:
For BN44-00341B; cut and remove jumper JP852.
This jumper wire is located just below the part number stamp on the pc board, I've done several of these and it cures the problem.
Jotvguy
Mar 04, 2013 | Samsung LN46C650 TV
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
My Samsung DLP TV's pictures are flickering on the regular screen, but pictures are fine in PIP mode. How do you explain that phenom?
Set uses two tuners, one for regular and one for PIP. If normal with DVD OR SOMETHING INTO REAR INPUTS, MAIN TUNER IS PROBLEM
sd tech
Aug 21, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
Ekse
