Cantv figure out how to turn on the date stamp on the menu option on the camera also low battery signal is almost always on no matter what type of batteries i use
SOURCE: Embed Date-Canon PowerShot A530
The only way to have the Date directly on the photo is to change your picture size into postcard mode. do that by hitting function set, and going to the bottom of the options where you choose your picture size... after that do what you described above, however the option will not be greyed out... that will put the pictures directly on the photo... warning!! the reason they make it a pain in the rear is because it will be on all pictures all the time.. no way to remove after!!! you can get several photo programs that will let you insert the date on only the pictures you choose.. Or you can go somewhere other then walmart where the technicians aren't required to have them ready in an hour... yes.. speed isn't always best... and they should be able to choose it in there settings... because the Date is always in your file Data... just not being displayed.. Or go get a little photo printer and print the ones you want... average cost.. 30 cents.. a little more.. but you have the control!! and you don't have to burn and gas while doing so!! Cheers
SOURCE: date stamp option in menu
For some cameras this option only works when the camera is set to a specific resolution. Some calle this resolution "Postcard" resolution, and is usually 1200 pixels width. Try setting your camera to its other resolutions to see if this ocrrects the problem. Suggest that you start with 1200 x 900 resolution. Keep in mind that this 1200 x 900 gives only 1 megapixel resolution. Most newer cameras are capable of taking much higher resolution pictures, so this may be a trade-off if you want to use the date stamp option.
SOURCE: date stamp will not show on my camera
I found the solution o-line. All I had to do was switch the camera to the 'postcard' mode and instant presto, I was able to access the date stamp mode. I want to express my thanks to the (I don't remember who) person who posted the solution.
SOURCE: how to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The
date will be printed on your images even if it has not been set at the
computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
SOURCE: i have a canon powershot
When you turn your camera on, there is a screen which appears in the viewfinder. Push the FUNC SET button and then scroll down the column on the left of your viewfinder until you come to the one with the letters M1 M2 M3 S, etc to the right. Then select the one called "Postcard 1600x1200" by scrolling to the right. Your camera is then in the post card mode. You can then go to the date stamp in the menu and your camera will not skip over it any longer! EUREKA!!
