Note:- I'm in the UK. Two problems which appear to be linked. Firstly, when I insert a tape into the camera, I often find it difficult to close the "door" (i.e. when this clicks shut, this activates the mechanism that lowers the cassette deck into the camera and spools the cassette around the heads), meaning that you cannot get the actual casette into the camera.
On inspection there appears to be two springs that help pull the "door" into place. When in place, this clicks two feeder runners which set off the insertion mechanism.
Also, if a tape insertion is successful an error message "Reinsert the cassette" appears on the screen display. The camera cannot be used.
Any help is much appreciated.
Thanks
SOURCE: error message 31:22 reinsert cassette tape
reel sensor is the problem of your camera it is a common problem to that model,maybe the pinch roller is loosen to the post cause of the lock of that is been broke..that roller is that one that pulling the tape...only a technician can put it back to the mechanism and replace that lock...in sony service they replace the whole assembly and cost a lots...i suggest find other service center for fixing it...hope that roller is not lost in your camera...
SOURCE: Sony Handycam Video Hi8 - TRV138- cassette - will not play -please reinsert
This happened to me in June. I used a head cleaner, and this seemed to work for about 2 months. Then the same problem again...
SOURCE: reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
SOURCE: Reinsert Cassette Error
Hi, I had the same problem. When I inserted the new (or old ) cassette, it was showing me the same simbol as you are describing here.... The one thing to do here is to let it check in some CamcorderReparingCentre. After I let it to repare it they told me that there was some kind of engine broken , I paid £60 for reparing but my camcorder is working again,properly like before...
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
