You can change the language that displays in the screens and menus of your device. To change the display language, perform the following steps: 1. Press the Left Softkey to select Start. 2. Select Settings and then Regional Settings. 3. In the Language field, use the Navigation key to select your language. 4. To save the setting, press the Left Softkey to select Done. You must turn your device off and on again for the change to take effect.
SOURCE: change language to english
yes you can change it via editted rom file with hex editor change it GER to ENG
